h-yuusuke
2022年3月24日 14時34分
掲題の件について、BaseOS上でfbiコマンドを使用するためapkコマンドでインストールしようとしたところ、下記エラーとなりインストールできませんでした。
armadillo:~# apk add fbida-fbi fetch https://download.atmark-techno.com/alpine/v3.15/atmark/aarch64/APKINDEX.tar.gz 281473741995080:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:ssl/statem/statem_clnt.c:1914: ERROR: https://download.atmark-techno.com/alpine/v3.15/atmark: Permission denied WARNING: Ignoring https://download.atmark-techno.com/alpine/v3.15/atmark: No such file or directory fetch https://dl-cdn.alpinelinux.org/alpine/v3.15/main/aarch64/APKINDEX.tar.gz 281473741995080:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:ssl/statem/statem_clnt.c:1914: ERROR: https://dl-cdn.alpinelinux.org/alpine/v3.15/main: Permission denied WARNING: Ignoring https://dl-cdn.alpinelinux.org/alpine/v3.15/main: No such file or directory fetch https://dl-cdn.alpinelinux.org/alpine/v3.15/community/aarch64/APKINDEX.tar.gz 281473741995080:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:ssl/statem/statem_clnt.c:1914: ERROR: https://dl-cdn.alpinelinux.org/alpine/v3.15/community: Permission denied WARNING: Ignoring https://dl-cdn.alpinelinux.org/alpine/v3.15/community: No such file or directory WARNING: The repository tag for world dependency 'atmark-x2-base@atmark' does not exist WARNING: The repository tag for world dependency 'conmon@atmark' does not exist WARNING: The repository tag for world dependency 'emmc-sref@atmark' does not exist WARNING: The repository tag for world dependency 'libubootenv@atmark' does not exist WARNING: The repository tag for world dependency 'linux-at@atmark' does not exist WARNING: The repository tag for world dependency 'modemmanager@atmark' does not exist WARNING: The repository tag for world dependency 'swupdate@atmark' does not exist ERROR: Not committing changes due to missing repository tags. Use --force-broken-world to override.
また、apk updateも試してみましたが、こちらでも下記エラーとなりました。
armadillo:~# apk update fetch https://download.atmark-techno.com/alpine/v3.15/atmark/aarch64/APKINDEX.tar.gz 281473295780936:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:ssl/statem/statem_clnt.c:1914: ERROR: https://download.atmark-techno.com/alpine/v3.15/atmark: Permission denied WARNING: Ignoring https://download.atmark-techno.com/alpine/v3.15/atmark: No such file or directory fetch https://dl-cdn.alpinelinux.org/alpine/v3.15/main/aarch64/APKINDEX.tar.gz 281473295780936:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:ssl/statem/statem_clnt.c:1914: ERROR: https://dl-cdn.alpinelinux.org/alpine/v3.15/main: Permission denied WARNING: Ignoring https://dl-cdn.alpinelinux.org/alpine/v3.15/main: No such file or directory fetch https://dl-cdn.alpinelinux.org/alpine/v3.15/community/aarch64/APKINDEX.tar.gz 281473295780936:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:ssl/statem/statem_clnt.c:1914: ERROR: https://dl-cdn.alpinelinux.org/alpine/v3.15/community: Permission denied WARNING: Ignoring https://dl-cdn.alpinelinux.org/alpine/v3.15/community: No such file or directory 3 errors; 185 distinct packages available
何が原因かわかりますでしょうか?
なお、BaseOSのバージョンは下記の通りです。
armadillo:~# cat /proc/version Linux version 5.10.101-1-at (builder@a3a29b8c603b) (aarch64-alpine-linux-musl-gcc (Alpine 10.3.1_git20211027) 10.3.1 20211027, GNU ld (GNU Binutils) 2.37) #2-Alpine SMP PREEMPT Mon Feb 21 22:14:25 UTC 2022
2022年3月24日 14時55分
h-yuusukeさん、
証明が認識されない時はほとんどの場合タイムサーバから時間を設定できなかった場合だと思いますが、確認してもらえますか?
社内のネットワークから外部のNTPサーバーが使えない場合に、自分のサーバーを設定するはできます。
(以下の例は来週のマニュアルアップデートに足す予定です…遅くなって申し訳ございません)
