sasa0107
2016年7月7日 10時47分
笹倉と申します。
Armadillo-IoT G2 でSDブート中に止まってしまいます。
下記にブート中のメッセージを記載致します。
hermit> boot
mmcsd: SD card at address 0x0000aaaa
mmcsd: SS08G 7761920KiB
gendisk: /dev/mmcblk1p1: start=0x0000000a, size=0x00ecdf38
gendisk: linux.bin.gz is found. (3544431 Bytes)
Copying kernel..done.
Uncompressing kernel...................................................................................................................................................................................................................................done.
Doing console=ttymxc1,115200
Doing root=/dev/mmcblk1p1
Doing noinitrd
Doing rootwait
Initializing cgroup subsys cpuset
Initializing cgroup subsys cpuacct
Linux version 3.14.36-at3 (atmark@atde5) (gcc version 4.6.3 (Debian 4.6.3-14atmark1) ) #6 PREEMPT Thu Dec 17 14:29:30 JST 2015
CPU: VIVT data cache, VIVT instruction cache
Machine: Armadillo-410
Memory policy: Data cache writeback
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Kernel command line: console=ttymxc1,115200 root=/dev/mmcblk1p1 noinitrd rootwait
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
allocated 262144 bytes of page_cgroup
please try 'cgroup_disable=memory' option if you don't want memory cgroups
Memory: 114800K/131072K available (5068K kernel code, 285K rwdata, 1660K rodata, 239K init, 295K bss, 16272K reserved)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xc8800000 - 0xff000000 ( 872 MB)
lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc069a4fc (6730 kB)
.init : 0xc069b000 - 0xc06d6d24 ( 240 kB)
.data : 0xc06d8000 - 0xc071f6ac ( 286 kB)
.bss : 0xc071f6ac - 0xc076938c ( 296 kB)
NR_IRQS:16 nr_irqs:16 16
MXC IRQ initialized
Switching to timer-based delay loop
sched_clock: 32 bits at 66MHz, resolution 15ns, wraps every 64585974768ns
Calibrating delay loop (skipped), value calculated using timer frequency.. 133.00 BogoMIPS (lpj=665000)
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Initializing cgroup subsys memory
Initializing cgroup subsys devices
Initializing cgroup subsys freezer
Initializing cgroup subsys blkio
Setting up static identity map for 0x804cc698 - 0x804cc6f0
devtmpfs: initialized
regulator-dummy: no parameters
imx25-pinctrl imx25-pinctrl.0: initialized IMX pinctrl driver
bio: create slab at 0
adc081c Vref: at 3300 mV
eSDHC1 Vcc: at 3300 mV
eSDHC2 Vcc: at 3300 mV
USB VBUS: at 5000 mV
SCSI subsystem initialized
pca953x 3-0071: interrupt support not compiled in
i2c-gpio i2c-gpio.3: using pins 17 (SDA) and 18 (SCL)
i2c-gpio i2c-gpio.4: using pins 66 (SDA) and 65 (SCL)
i2c i2c-0: IMX I2C adapter registered
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti
PTP clock support registered
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.18
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
No add-on expansion board detected at CON1.
Toa Musen Denki Wi-SUN board detected at CON2(Rev 1, SerialNumber=16010004).
Switched to clocksource mxc_timer1
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP: reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Trying to unpack rootfs image as initramfs...
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 7260K (c1000000 - c1717000)
futex hash table entries: 256 (order: -1, 3072 bytes)
audit: initializing netlink subsys (disabled)
audit: type=2000 audit(0.709:1): initialized
VFS: Disk quotas dquot_6.5.2
msgmni has been set to 238
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
io scheduler noop registered
imx-sdma imx25-sdma: loaded firmware 1.0
imx-sdma imx25-sdma: initialized
imx21-uart.1: ttymxc1 at MMIO 0x43f94000 (irq = 48, base_baud = 7500000) is a IMX
console [ttymxc1] enabled
imx21-uart.0: ttymxc0 at MMIO 0x43f90000 (irq = 61, base_baud = 7500000) is a IMX
brd: module loaded
loop: module loaded
physmap platform flash device: 02000000 at a0000000
physmap-flash: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000089 Chip ID 0x00891c
Using buffer write method
Creating 4 MTD partitions on "physmap-flash":
0x000000000000-0x000000020000 : "nor.bootloader"
0x000000020000-0x000000420000 : "nor.kernel"
0x000000420000-0x000001f00000 : "nor.userland"
0x000001f00000-0x000002000000 : "nor.config"
libphy: fec_enet_mii_bus: probed
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver sierra_net
usbcore: registered new interface driver cdc_ncm
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbserial: USB Serial support registered for Sierra USB modem
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
rtc-s35390a 3-0030: rtc core: registered rtc-s35390a as rtc0
i2c /dev entries driver
lm75 3-0048: hwmon0: sensor 'lm75b'
imx2-wdt imx2-wdt.0: timeout 60 sec (nowayout=0)
usbcore: registered new interface driver btusb
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: no vqmmc regulator found
mmc0: SDHCI controller on sdhci-esdhc-imx25.0 [sdhci-esdhc-imx25.0] using DMA
mmc1: no vqmmc regulator found
mmc1: SDHCI controller on sdhci-esdhc-imx25.1 [sdhci-esdhc-imx25.1] using DMA
usbhid: USB HID core driver
usbcore: registered new interface driver snd-usb-caiaq
oprofile: no performance counters
oprofile: using timer interrupt.
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (1907 buckets, 7628 max)
ipip: IPv4 over IPv4 tunneling driver
gre: GRE over IPv4 demultiplexor driver
ip_gre: GRE over IPv4 tunneling driver
TCP: cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 10
ip6_tables: (C) 2000-2006 Netfilter Core Team
sit: IPv6 over IPv4 tunneling driver
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
registered taskstats version 1
regulator-dummy: incomplete constraints, leaving on
input: gpio-keys as /devices/platform/gpio-keys/input/input0
input: gpio-keys-polled as /devices/platform/gpio-keys-polled/input/input1
rtc-s35390a 3-0030: setting system clock to 2000-01-01 00:09:00 UTC (946685340)
ALSA device list:
No soundcards found.
Waiting for root device /dev/mmcblk1p1...
mmc1: new high speed SDHC card at address aaaa
mmcblk0: mmc1:aaaa SS08G 7.40 GiB
mmcblk0: p1
random: nonblocking pool is initialized
このラインで止まってしまいます。
SDの中ですが
[root@armadillo-iotg (ttymxc1) ~]# ls -l /mnt
total 284
-rw-r--r-- 1 root root 3244 Dec 17 2015 COPYRIGHT
-rw-r--r-- 1 root root 178403 Dec 17 2015 THIRDPARTYLICENSEREADME.txt
drwxr-xr-x 2 root root 4096 Jan 1 2000 bin/
-rw-r--r-- 1 root root 8526 Dec 17 2015 bom
drwxr-xr-x 2 root root 4096 Jan 1 09:04 boot/
drwxr-xr-x 4 root root 4096 Jan 1 2000 dev/
drwxr-xr-x 16 root root 4096 Jan 1 2000 etc/
drwxr-xr-x 5 root root 4096 Jan 1 2000 home/
drwxr-xr-x 11 root root 4096 Jan 1 2000 lib/
lrwxrwxrwx 1 root root 11 Jan 1 2000 linuxrc -> bin/busybox*
drwx------ 2 root root 16384 Dec 17 2015 lost+found/
drwxr-xr-x 2 root root 4096 Dec 17 2015 media/
drwxr-xr-x 2 root root 4096 Dec 17 2015 mnt/
drwxr-xr-x 4 root root 4096 Jan 1 2000 opt/
drwxr-xr-x 2 root root 4096 Dec 17 2015 proc/
-rw-r--r-- 1 root root 570 Dec 17 2015 release
drwxr-xr-x 2 root root 4096 Dec 17 2015 root/
drwxr-xr-x 2 root root 4096 Dec 17 2015 run/
drwxr-xr-x 2 root root 4096 Jan 1 2000 sbin/
drwxr-xr-x 2 root root 4096 Dec 17 2015 sys/
drwxr-xr-x 2 root root 4096 Dec 17 2015 tmp/
drwxr-xr-x 6 root root 4096 Jan 1 2000 usr/
drwxr-xr-x 9 root root 4096 Jan 1 2000 var/
となっています。
SDブート用のSDカードは
を参考に作成致しました。
カーネルイメージの配置は、自社でmakeした”linux.bin.gz”を/mnt/boot/にコピーしました。
Atmark-Dist イメージから構築は、自社でmakeした”romfs.img.gz”を解凍し、
mount -o loop tmp/romfs.img romfs/
(cd romfs/; tar cf - *) | (cd /mnt; tar xf -)
で展開致しました。
この自社でmakeした”linux.bin.gz”と”romfs.img.gz”は、netflashcを使用して、
Armadillo-IoTのフラッシュメモリを書き換え、フラッシュメモリからの起動の際は、
問題なくブートしております。
以上、SDブート時にブートが止まる原因が何かお分かりでしたら、ご教授下さい。
お願い致します。
sasa0107
2016年7月7日 12時04分
花田 様
笹倉です。
無事ブートできました。
有難うございました。
> 花田です。
> と、rootシステムディスクにmmcblk1を指定しているのに
> > mmcblk0: p1
> 実際にSDが差さっているのはmmcblk0、この点だけだと思います。
> root=/dev/mmcblk0p1
> に変更して、試してみてください。
at_hanada
2016年7月7日 11時41分
花田です。
> mmcblk0: p1
root=/dev/mmcblk0p1
に変更して、試してみてください。
