s.kurachi
2024年9月11日 13時17分
開発マニュアルの以下の項目を参考にして、ABOS WebからOpenVPNの設定を試みています。
コンテナイメージ「alpine_openvpn」は作成されるのですが、以下のようなエラーが出力されて、VPNの設定に失敗します。
WARNING: /usr/sbin/abos-ctrl podman-rw does not make sense with podman-storage as disk, running podman STEP 1/2: FROM docker.io/alpine:latest STEP 2/2: RUN apk add --no-cache openvpn fetch https://dl-cdn.alpinelinux.org/alpine/v3.20/main/aarch64/APKINDEX.tar.gz fetch https://dl-cdn.alpinelinux.org/alpine/v3.20/community/aarch64/APKINDEX.tar.gz (1/9) Installing libcap2 (2.70-r0) (2/9) Installing zstd-libs (1.5.6-r0) (3/9) Installing libelf (0.191-r0) (4/9) Installing libmnl (1.0.5-r2) (5/9) Installing iproute2-minimal (6.9.0-r0) (6/9) Installing libcap-ng (0.8.5-r0) (7/9) Installing lz4-libs (1.9.4-r5) (8/9) Installing lzo (2.10-r5) (9/9) Installing openvpn (2.6.11-r0) Executing openvpn-2.6.11-r0.pre-install Executing busybox-1.36.1-r29.trigger OK: 12 MiB in 23 packages COMMIT alpine_openvpn:latest --> 0fcca7c60b61 Successfully tagged localhost/alpine_openvpn:latest 0fcca7c60b612b1f7be86d83ea9c715f2a92c2807ccc1530a55135fa6f637f83 Starting 'mapserver' time="2024-09-11T11:12:52+09:00" level=warning msg="The input device is not a TTY. The --tty and --interactive flags might not work properly" db334abedb4b55ac36e059f1054d030f3f6da42140bf796b4e6264e829830077 Starting 'rabbitmq_server' time="2024-09-11T11:12:53+09:00" level=warning msg="The input device is not a TTY. The --tty and --interactive flags might not work properly" 2a12acd56a4a73e0860cd8c9648e21fb7b5e582ef17afb163491251fa715a583 Starting 'status_checker' time="2024-09-11T11:12:54+09:00" level=warning msg="The input device is not a TTY. The --tty and --interactive flags might not work properly" 16b6773de0aaa38cf1a91d9001bc51c855570196e36d6a1d553d9fd7da337593 error: volume root /root/output.log must exist Error: name or ID cannot be empty Nothing to do, none of the requested files exist: /etc/atmark/abos_web/openvpn Nothing to do, none of the requested files exist: /etc/atmark/containers/abos_web_openvpn.conf Nothing to do, none of the requested files exist: /etc/dnsmasq.d/openvpn_dns.conf dnsmasq | * WARNING: you are stopping a boot service * Stopping dnsmasq ... [ ok ] * Starting dnsmasq ... [ ok ]
なにか原因として考えられることはありますでしょうか?
なお、Starting ' ' で起動しているコンテナは、私のほうで自動起動するように指定したコンテナです。
s.kurachi
2024年9月11日 15時44分
> 佐藤です。
> 確認させてください。それらのコンテナを自動起動しないようにした場合は、エラーはでないのでしょうか。
コンテナを自動起動させないように設定して、VPNの設定をしました。
同様のエラーで失敗しています。コンテナの自動起動とは関係が無いようです。
WARNING: /usr/sbin/abos-ctrl podman-rw does not make sense with podman-storage as disk, running podman STEP 1/2: FROM docker.io/alpine:latest STEP 2/2: RUN apk add --no-cache openvpn --> Using cache d533b49eba123ef68f8d3794cb2476771420c98d1d9fc72018c4655d09516a1a COMMIT alpine_openvpn:latest --> d533b49eba12 Successfully tagged localhost/alpine_openvpn:latest d533b49eba123ef68f8d3794cb2476771420c98d1d9fc72018c4655d09516a1a error: volume root /root/output.log must exist Error: name or ID cannot be empty Nothing to do, none of the requested files exist: /etc/atmark/abos_web/openvpn Nothing to do, none of the requested files exist: /etc/atmark/containers/abos_web_openvpn.conf Nothing to do, none of the requested files exist: /etc/dnsmasq.d/openvpn_dns.conf dnsmasq | * WARNING: you are stopping a boot service * Stopping dnsmasq ... [ ok ] * Starting dnsmasq ... [ ok ]
s.kurachi
2024年9月11日 17時06分
> 佐藤です。
> ありがとうございます。
> 何度もすいません、以下のコマンドの結果はどうでしょうか。
次のようになりました。
alpine.conf.exampleとat-debian-image.conf.example以外は、私が後から作成したファイルになります。
armadillo:~# ls -a /etc/atmark/containers . noise.conf .. rabbitmq_server.conf README radio.conf alpine.conf.example samba.conf at-debian-image.conf.example status_checker.conf main.conf temp_log.conf mapserver.conf web.conf mq.conf armadillo:~# ls -a /etc/atmark/containers . alpine.conf.example mapserver.conf rabbitmq_server.conf status_checker.conf .. at-debian-image.conf.example mq.conf radio.conf temp_log.conf README main.conf noise.conf samba.conf web.conf armadillo:~# grep -r add_volume /etc/atmark/containers /etc/atmark/containers/mq.conf:add_volumes \ /etc/atmark/containers/samba.conf:add_volumes /var/app/volumes/storage:/home/shares/samba /etc/atmark/containers/noise.conf:add_volumes \ /etc/atmark/containers/status_checker.conf:add_volumes /var/run/dbus:/var/run/dbus /etc/atmark/containers/at-debian-image.conf.example:add_volumes /opt/firmware:/opt/firmware:ro /etc/atmark/containers/at-debian-image.conf.example:add_volumes /tmp/xdg_home:/run/xdg_home /etc/atmark/containers/radio.conf:add_volumes \ /etc/atmark/containers/main.conf:add_volumes \ /etc/atmark/containers/temp_log.conf:add_volumes \ /etc/atmark/containers/web.conf:add_volumes \ /etc/atmark/containers/rabbitmq_server.conf:add_volumes /var/app/volumes/rabbitmq:/etc/rabbitmq /etc/atmark/containers/mapserver.conf:add_volumes /var/app/volumes/mapserver:/etc/mapserver
s.kurachi
2024年9月11日 17時23分
> > 佐藤です。
> > ありがとうございます。
> 次のようになりました。
申し訳ありません。
こちらの件、原因が分かりました。
以下のエラーは、私が作成したファイル「temp_log.conf」が原因で出力されているものでした。
「temp_log.conf」の中でoutput.logに関する記述がありました。
confファイル自体を削除したところ、VPNの設定が通りました。
こちら、昔に作成したファイルで、コンテナイメージも既に削除していたため、気が付きませんでした。
お手数をおかけしまして、大変失礼いたしました。
at_makoto.sato
2024年9月11日 14時38分
佐藤です。
