nagaishi
2016年12月13日 18時51分
armadillo-440上で、glade動かしているのですが
時々、アプリケーションが強制終了します。
その際に、以下のようなメッセージが出力されています。
何か原因がわかるようでしたら、ご教示いただけないでしょうか?
(app01:1438): GLib-GObject-CRITICAL **: g_object_ref: assertion `object->ref_count > 0' failed
(app01:1438): GLib-GObject-CRITICAL **: g_object_unref: assertion `object->ref_count > 0' failed
(app01:1438): Pango-CRITICAL **: pango_renderer_draw_layout: assertion `PANGO_IS_LAYOUT (layout)' failed
(app01:1438): Pango-CRITICAL **: pango_layout_get_pixel_extents: assertion `PANGO_IS_LAYOUT (layout)' failed
(app01:1438): GLib-GObject-CRITICAL **: g_object_unref: assertion `G_IS_OBJECT (object)' failed
(app01:1438): Gtk-CRITICAL **: gtk_render_layout: assertion `PANGO_IS_LAYOUT (layout)' failed
Segmentation fault
(app01:1572): GLib-GObject-CRITICAL **: g_object_ref: assertion `G_IS_OBJECT (object)' failed
(app01:1572): GLib-GObject-CRITICAL **: g_object_unref: assertion `G_IS_OBJECT (object)' failed
(app01:1572): Pango-CRITICAL **: pango_layout_get_pixel_extents: assertion `PANGO_IS_LAYOUT (layout)' failed
(app01:1572): GLib-GObject-CRITICAL **: g_object_ref: assertion `object->ref_count > 0' failed
(app01:1572): GLib-GObject-CRITICAL **: g_object_unref: assertion `object->ref_count > 0' failed
(app01:1572): Pango-CRITICAL **: pango_layout_get_extents: assertion `layout != NULL' failed
(app01:1572): Pango-CRITICAL **: pango_layout_get_line_count: assertion `layout != NULL' failed
(app01:1572): Gtk-CRITICAL **: gtk_render_layout: assertion `PANGO_IS_LAYOUT (layout)' failed
(app01:1572): Pango-CRITICAL **: pango_cairo_show_layout: assertion `PANGO_IS_LAYOUT (layout)' failed
app01: /build/buildd-cairo_1.12.2-3-armel-v1aiIO/cairo-1.12.2/src/cairo-region.c:423: cairo_region_destroy: Assertion `((*&(®ion->ref_count)->ref_count) > 0)' failed.
Aborted
(app01:1739): GLib-GObject-CRITICAL **: g_object_ref: assertion `object->ref_count > 0' failed
Pango:ERROR:/build/buildd-pango1.0_1.30.0-1-armel-443Bm7/pango1.0-1.30.0/./pango/pango-layout.c:3877:pango_layout_check_lines: assertion failed: (end <= (layout->text + layout->length))
Aborted
Aborted
at_yashi
2016年12月13日 19時08分
破壊したオブジェクトに触っていませんか?
g_log() に break point を仕掛けて、gdb で backtrace を取ってみてはどうでしょう?
あとは、再現できる最小コードがあれば、なにかコメントできると思います。
