djieo3da
2025年2月26日 8時04分
製品型番:Armadillo-IoT A6E
Debian/ABOSバージョン:3.20.3-at.3
カーネルバージョン:5.10.226-0-at
3G/LTE モジュール情報 (Debianのみ):
その他:
下記ページを参考にArmadillo-IoT A6Eイメージのバックアップを試してみましたが上手くいきません。
https://armadillo.atmark-techno.com/forum/armadillo/21582
下記は実行時のメッセージです。
SWUpdate v2024.05.2_git20240718-r0
[INFO ] : SWUPDATE running : [print_registered_handlers] : no handler registered.
[WARN ] : SWUPDATE running : [read_lines_notify] : ----------------------------------------------
[WARN ] : SWUPDATE running : [read_lines_notify] : WARNING: Persistent storage is used for podman, stopping all containers before updating
[INFO ] : SWUPDATE running : [read_lines_notify] : Command 'command podman stop -a' output:
[INFO ] : SWUPDATE running : [read_lines_notify] : 419337ae13be1176f785b0c02052627ff521f3812b756cfef6ff7c797f20f3fd
[INFO ] : SWUPDATE running : [read_lines_notify] : /target/mnt/installer.img-in-progress (572MB) was bigger than 540MB and was not truncated.
[ERROR] : SWUPDATE failed [0] ERROR : ERROR: Aborting at user request
[INFO ] : SWUPDATE running : [read_lines_notify] : WARNING: using emmc for podman-storage is a development option and not supported for production
[INFO ] : SWUPDATE running : [read_lines_notify] : WARNING: consider switching back to tmpfs with 'abos-ctrl podman-storage --tmpfs' first
[INFO ] : SWUPDATE running : [read_lines_notify] : Continue building image? [y/N]
[INFO ] : SWUPDATE running : [read_lines_notify] : Terminating, cleaning up...
[ERROR] : SWUPDATE failed [0] ERROR : Command failed: sh -c 'abos-ctrl make-installer --noprompt --output /target/mnt/installer.img' >&${SWUPDATE_INFO_FD:-1} -- /var/tmp/swupdate-abosweb-upload.BKELJM/sh__c__abos_ctrl_mak..PDATE_INFO_FD__1_____0382716ade545c4737b8829299495e6782442d8c
[ERROR] : SWUPDATE failed [0] ERROR : Error streaming _home_atmark_mkswu__..PDATE_INFO_FD__1_____2b87381ea01e4601872c7f99c390eb77c93d9d8d
[ERROR] : SWUPDATE failed [1] Image invalid or corrupted. Not installing ...
[INFO ] : SWUPDATE running : [read_lines_notify] : Restarting containers
[ERROR] : SWUPDATE failed [0] ERROR : time="2025-02-26T07:59:52+09:00" level=warning msg="The input device is not a TTY. The --tty and --interactive flags might not work properly"
[ERROR] : SWUPDATE failed [0] ERROR : time="2025-02-26T08:00:00+09:00" level=warning msg="The input device is not a TTY. The --tty and --interactive flags might not work properly"
[ERROR] : SWUPDATE failed [0] ERROR : Error: localhost/example2:latest: image not known
[ERROR] : SWUPDATE failed [0] ERROR : error: Could not start example2
[ERROR] : SWUPDATE failed [0] ERROR : SWUpdate *failed* !
djieo3da
> 太田です。
> SWUpdate のメッセージに
> [INFO ] : SWUPDATE running : [read_lines_notify] : WARNING: using emmc for podman-storage is a development option and not supported for production > > [INFO ] : SWUPDATE running : [read_lines_notify] : WARNING: consider switching back to tmpfs with 'abos-ctrl podman-storage --tmpfs' first >
> とありますので、コンテナイメージのストレージを eMMC にしているためだと思われます。
> 以下のコマンドをArmadillo 上で実施したのち、もう一度 SWU イメージインストールするとどうなりますでしょうか?
> armadillo:~# abos-ctrl podman-storage --tmpfs >
> どうぞよろしくお願いいたします。
ありがとうございます。
SWU イメージインストールができました。
at_satoshi.ohta
2025年2月26日 9時26分
太田です。
SWUpdate のメッセージに
どうぞよろしくお願いいたします。
