akira.shimomura
2017年1月12日 10時05分
Armadillo-IoT G3LでのLTE通信について質問です。
Armadillo-IoT G3LにSIMを挿入し、G3L 製品マニュアル「7.2.6. LTE」章の手順に従い、LTEの設定を
行いましたが、LTE通信がうまく動作しません。
NetworkManager/ModemManagerのログレベルをDebugにして確認したところ、
ModemManager[428]: <debug> (ttyACM0): --> 'AT+CGPADDR<CR>' ModemManager[428]: <debug> (ttyACM0): <-- '<CR><LF>+CGPADDR: 1,"10.xxx.xxx.xxx"<CR><LF>' ModemManager[428]: <debug> (ttyACM0): <-- '<CR><LF>OK<CR><LF>' ModemManager[428]: <debug> ELS31-J Connected
とLTE接続はできているようなのですが、
NetworkManager[2418]: <debug> [27295.053848] [nm-dbus-manager.c:160] private_server_new_connection(): (dhcp) accepted connection 0xcfe868 on private socket. NetworkManager[2418]: <info> (usb1): DHCPv4 state changed nbi -> preinit NetworkManager[2418]: <debug> [27295.057308] [devices/nm-device.c:2708] dhcp4_state_changed(): (ttyACM0): new DHCPv4 client state 1 NetworkManager[2418]: <debug> [27295.058588] [nm-dbus-manager.c:117] private_server_message_filter(): (dhcp) closed connection 0xcfe868 on private socket. dhclient: DHCPREQUEST on usb1 to 255.255.255.255 port 67 dhclient: DHCPACK from 192.168.15.1 NetworkManager[2418]: <debug> [27295.124511] [nm-dbus-manager.c:160] private_server_new_connection(): (dhcp) accepted connection 0xcfe820 on private socket. NetworkManager[2418]: <info> (usb1): DHCPv4 state changed preinit -> reboot NetworkManager[2418]: <debug> [27295.128653] [devices/nm-device.c:2708] dhcp4_state_changed(): (ttyACM0): new DHCPv4 client state 8 NetworkManager[2418]: <info> address 192.168.15.130 NetworkManager[2418]: <info> plen 24 (255.255.255.0) NetworkManager[2418]: <info> gateway 192.168.15.1 NetworkManager[2418]: <info> server identifier 192.168.15.1 NetworkManager[2418]: <info> lease time 43200 NetworkManager[2418]: <info> hostname 'armadillo' NetworkManager[2418]: <info> nameserver '192.168.15.1' NetworkManager[2418]: <info> domain name 'lan' NetworkManager[2418]: <info> Activation (ttyACM0) Stage 5 of 5 (IPv4 Configure Commit) scheduled... NetworkManager[2418]: <debug> [27295.136977] [nm-dbus-manager.c:117] private_server_message_filter(): (dhcp) closed connection 0xcfe820 on private socket. NetworkManager[2418]: <info> Activation (ttyACM0) Stage 5 of 5 (IPv4 Commit) started... NetworkManager[2418]: <debug> [27295.140176] [platform/nm-platform.c:1445] nm_platform_ip4_address_add(): address: adding or updating IPv4 address: 192.168.15.130/24 lft 43205sec pref 43205sec lifetime 42-0[43205,43205] dev usb1 src unknown NetworkManager[2418]: <debug> [27295.142312] [platform/nm-linux-platform.c:456] get_kernel_object(): get_kernel_object for type 2 returned 0xcfc150 NetworkManager[2418]: <debug> [27295.143463] [platform/nm-platform.c:2571] log_ip4_address(): signal: address 4 added: 192.168.15.130/24 lft 43205sec pref 43205sec lifetime 42-42[43205,43205] dev usb1 src kernel
と、なぜか不明DHCPサーバーによりIPアドレスが割り当てられてしまう状況となっています。
DHCPサーバーによるIPアドレスの割り当てが行われないようにし、最初に通知されたIPアドレスで設定してLTE通信を
行えるようにする手順についてご教示ください。
使用しているSIMは、Windows等でLTE通信が行えることは確認できています。
また、Armadillo-IoT G3Lは購入したままの状態で、ファームウェアの入れ替え等は行っていません。
akira.shimomura
2017年1月16日 9時38分
Armadillo-IoT G3Lで、色々試行錯誤しましたが、NetworkManagerによるLTE接続設定が行えないようなので、
pppdによるLTE接続設定を行おうと考えています。
Armadillo-IoT G3LのLTE接続設定をpppdで行うことは可能でしょうか?
また、pppdによるLTE接続設定の設定例・注意点等がありましたらご教示ください。
