h.t
2018年5月1日 14時57分
先日のキャンペーンを利用して、Armadillo-640へ社内製品をのせる為の動作確認等を行っています。
SDカードブートに変更し、SDカードでの起動には成功したのですが、
rebootコマンドもしくはshutdown -rを実行すると下記のログで止まってしまいます。
また、作業影響も考え、u-bootでenv default -aを実行し、eMMCでのブートに戻しても結果は同様でした。
何か対応策はございますでしょうか。
root@armadillo:~# reboot [ OK ] Stopped target Timers. [ OK ] Stopped Daily Cleanup of Temporary Directories. Stopping User Manager for UID 0... [ OK ] Stopped target Graphical Interface. [ OK ] Stopped target Multi-User System. Stopping Regular background program processing daemon... [ OK ] Stopped target Login Prompts. Stopping D-Bus S� Stopping Session c1 of user root. Stopping System Logging Service... [ OK ] Stopped Daily apt upgrade and clean activities. [ OK ] Stopped Daily apt download activities. Stopping Getty on tty1... Stopping LSB: exim Mail Transport Agent... [ OK ] Stopped Regular background program processing daemon. [ OK ] Stopped System Logging Service. [ OK ] Stopped D-Bus System Message Bus. [ OK ] Stopped Getty on tty1. [ OK ] Stopped Serial Getty on ttymxc0. [ OK ] Stopped Session c1 of user root. [ OK ] Removed slice system-serial\x2dgetty.slice. [ OK ] Stopped /etc/rc.local Compatibility. [ OK ] Removed slice system-getty.slice. [ OK ] Stopped LSB: exim Mail Transport Agent. [ OK ] Stopped target Network is Online. [ OK ] Stopped target System Time Synchronized. [ OK ] Stopped User Manager for UID 0. [ OK ] Removed slice User Slice of root. Stopping Permit User Sessions... Stopping Login Service... [ OK ] Stopped Login Service. [ OK ] Stopped Permit User Sessions. [ OK ] Stopped target Remote File Systems. [ OK ] Stopped target Network. Stopping Raise network interfaces... [ OK ] Stopped target Basic System. [ OK ] Stopped target Slices. [ OK ] Removed slice User and Session Slice. [ OK ] Stopped target Paths. [ OK ] Stopped target Sockets. [ OK ] Closed D-Bus System Message Bus Socket. [ OK ] Stopped target System Initialization. Stopping Load/Save Random Seed... Stopping Network Time Synchronization... [ OK ] Stopped target Encrypted Volumes. [ OK ] Stopped Forward Password Requests to Wall Directory Watch. [ OK ] Stopped Dispatch Password Requests to Console Directory Watch. Stopping Update UTMP about System Boot/Shutdown... [ OK ] Stopped target Swap. [ OK ] Closed Syslog Socket. [ OK ] Stopped Network Time Synchronization. [ OK ] Stopped Load/Save Random Seed. [ OK ] Stopped Update UTMP about System Boot/Shutdown. [ OK ] Stopped Create Volatile Files and Directories. [ OK ] Stopped Raise network interfaces. [ OK ] Stopped Apply Kernel Variables. [ OK ] Stopped Load Kernel Modules. [ OK ] Stopped target Local File Systems. Unmounting /run/user/0... [ OK ] Unmounted /run/user/0. [ OK ] Reached target Unmount All Filesystems. [ OK ] Stopped target Local File Systems (Pre). [ OK ] Stopped Remount Root and Kernel File Systems. [ OK ] Stopped Create Static Device Nodes in /dev. [ OK ] Reached target Shutdown. [ 255.698275] systemd-shutdow: 27 output lines suppressed due to ratelimiting [ 257.894565] systemd-shutdown[1]: Sending SIGTERM to remaining processes... [ 257.916045] systemd-journald[72]: Received SIGTERM from PID 1 (systemd-shutdo w). [ 257.929486] systemd-shutdown[1]: Sending SIGKILL to remaining processes... [ 257.946109] systemd-shutdown[1]: Unmounting file systems. [ 257.953026] systemd-shutdown[1]: Remounting '/' read-only with options 'data= ordered'. [ 258.176318] EXT4-fs (mmcblk1p2): re-mounted. Opts: data=ordered [ 258.188520] systemd-shutdown[1]: Remounting '/' read-only with options 'data= ordered'. [ 258.197218] EXT4-fs (mmcblk1p2): re-mounted. Opts: data=ordered [ 258.203237] systemd-shutdown[1]: All filesystems unmounted. [ 258.208916] systemd-shutdown[1]: Deactivating swaps. [ 258.214208] systemd-shutdown[1]: All swaps deactivated. [ 258.219486] systemd-shutdown[1]: Detaching loop devices. [ 258.228337] systemd-shutdown[1]: All loop devices detached. [ 258.547592] ci_hdrc ci_hdrc.1: remove, state 1 [ 258.552100] usb usb2: USB disconnect, device number 1 [ 258.558573] ci_hdrc ci_hdrc.1: USB bus 2 deregistered [ 258.563930] ci_hdrc ci_hdrc.0: remove, state 1 [ 258.568415] usb usb1: USB disconnect, device number 1 [ 258.574989] ci_hdrc ci_hdrc.0: USB bus 1 deregistered [ 258.580361] reboot: Restarting system [ 259.584483] Reboot failed -- System halted
h.t
2018年5月1日 16時04分
> 現在Armadillo-640はrebootをサポートしていません。
> 6月までにアップデート予定です。もう暫くお待ちください。
> 参考:
> https://manual.atmark-techno.com/armadillo-640/armadillo-640_product_ma…
御回答ありがとうございます。
マニュアル見落としていました。大変失礼致しました。
at_ohsawa
2018年5月31日 18時03分
お待たせしております。
本日reboot対応版のソフトウェアをリリースいたしました。
ニュース:
https://armadillo.atmark-techno.com/news/20180531/software-update-a640
ダウンロード:
https://armadillo.atmark-techno.com/armadillo-640/downloads
at_ohsawa
2018年5月1日 15時02分
参考:
