kern.logのスタックトレースが発生
toru.kabasawa
2020年4月9日 16時05分
armadillo-x1(Linux version 4.9.133-at6 (atmark@atde7))のkern.logに
以下のスタックトレースが出ているのですが、
発生する原因はなんでしょうか?
また対策方法についても教えて頂けますでしょうか?
------------[ cut here ]------------
WARNING: CPU: 1 PID: 1 at drivers/cpufreq/cpufreq_interactive.c:371
irq_work+0x460/0x4c0
Modules linked in:
CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.9.133-at6 #394 Hardware name: Freescale i.MX7 Dual (Device Tree) [<8010f8e0>] (unwind_backtrace) from [<8010b478>] (show_stack+0x10/0x14) [<8010b478>] (show_stack) from [<803ec7ac>] (dump_stack+0x78/0x8c) [<803ec7ac>] (dump_stack) from [<80130cfc>] (__warn+0xe8/0x100) [<80130cfc>] (__warn) from [<80130dc4>] (warn_slowpath_null+0x20/0x28) [<80130dc4>] (warn_slowpath_null) from [<807cbad0>] (irq_work+0x460/0x4c0) [<807cbad0>] (irq_work) from [<801b3fd8>] (irq_work_run_list+0x7c/0xb8) [<801b3fd8>] (irq_work_run_list) from [<801b4040>] (irq_work_run+0x2c/0x44) [<801b4040>] (irq_work_run) from [<8010e608>] (handle_IPI+0xa0/0x1ac) [<8010e608>] (handle_IPI) from [<80101524>] (gic_handle_irq+0x88/0x8c) [<80101524>] (gic_handle_irq) from [<8010be4c>] (__irq_svc+0x6c/0xa8) Exception stack(0xa8089e18 to 0xa8089e60)
9e00: 815a6348 00000000
hub 2-1:1.0: 3 ports detected
9e20: ffb0e600 8085d44c 815fafa8 00001f3f 036445ab 815a6558 f5380000 30380000
9e40: f57a0000 307a0000 9667ffea a8089e68 803ea5f8 8010f220 a0010013 ffffffff [<8010be4c>] (__irq_svc) from [<8010f220>]
(arch_timer_read_counter_long+0x10/0x18)
[<8010f220>] (arch_timer_read_counter_long) from [<803ea5f8>]
(__timer_delay+0x48/0x58)
[<803ea5f8>] (__timer_delay) from [<8011cf00>] (imx7d_enable_rcosc+0x54/0x9c) [<8011cf00>] (imx7d_enable_rcosc) from [<8120a760>]
(imx7d_cpuidle_init+0x15c/0x1c8)
[<8120a760>] (imx7d_cpuidle_init) from [<8120bfdc>]
(imx7d_init_late+0x38/0x40)
[<8120bfdc>] (imx7d_init_late) from [<8120365c>]
(init_machine_late+0x20/0x90)
[<8120365c>] (init_machine_late) from [<801017fc>]
(do_one_initcall+0x44/0x16c)
[<801017fc>] (do_one_initcall) from [<81200e4c>]
(kernel_init_freeable+0x1cc/0x258)
[<81200e4c>] (kernel_init_freeable) from [<80bafccc>] (kernel_init+0x8/0x110) [<80bafccc>] (kernel_init) from [<80107790>] (ret_from_fork+0x14/0x24) ---[ end trace 8ba44c3cdbd2aa35 ]---
佐藤です。
発生する前と後でカーネルに対し変更した点などありますでしょうか。
例えば「あるカーネルコンフィギュレーションを変えたら発生するようになった」や
「デバイスツリーを変更したら発生するようになった」など。
佐藤様
回答ありがとうございました。
てっきりオリジナルの状態で発生している問題かと思いこんでおりましたが、
動作中のカーネルはカスタマイズされたもので発生している現象でした。
再度変更点の見直しを行います。
お手数をおかけしました。
