ito1997
2021年4月26日 12時15分
G2でrc.localにて、USBでArmadilloに書込み処理を行っていますが、失敗します。
成功時、失敗時のdiffは以下となりますが、対応策をご教示ください。
※G2には、MicroSDを付けていて、MicroSDをmount後、実行モジュールを
MicroSD内に書き込んでします。
※rc.localと成功時と失敗時のファイルを添付します。
※書込み失敗時は、モジュールは起動しません。
❯ diff -u success.txt error.txt --- success.txt 2021-04-26 11:37:49.036306800 +0900 +++ error.txt 2021-04-26 11:37:43.265611700 +0900 @@ -174,9 +174,9 @@ Initializing XFRM netlink socket mmcblk0: mmc0:aaaa SL08G 7.40 GiB NET: Registered protocol family 10 +usb-storage 1-1:1.0: USB Mass Storage device detected mmcblk0: p1 ip6_tables: (C) 2000-2006 Netfilter Core Team -usb-storage 1-1:1.0: USB Mass Storage device detected sit: IPv6 over IPv4 tunneling driver scsi0 : usb-storage 1-1:1.0 NET: Registered protocol family 17 @@ -200,41 +200,44 @@ regulator-dummy: incomplete constraints, leaving on input: gpio-keys as /devices/platform/gpio-keys/input/input0 input: gpio-keys-polled as /devices/platform/gpio-keys-polled/input/input1 -rtc-s35390a 3-0030: setting system clock to 2000-01-22 07:40:00 UTC (948526800) +rtc-s35390a 3-0030: setting system clock to 2000-01-22 07:36:16 UTC (948526576) ALSA device list: No soundcards found. RAMDISK: ext2 filesystem found at block 0 -RAMDISK: Loading 32768KiB [1 disk] into ram disk... | +RAMDISK: Loading 32768KiB [1 disk] into ram disk... - scsi 0:0:0:0: Direct-Access V2.321 RamBo 1100 PQ: 0 ANSI: 0 CCS -- -sd 0:0:0:0: [sda] 7700480 512-byte logical blocks: (3.94 GB/3.67 GiB) | -usb 2-1: new full-speed USB device number 3 using ci_hdrc +sd 0:0:0:0: [sda] 7700480 512-byte logical blocks: (3.94 GB/3.67 GiB) +/ sd 0:0:0:0: [sda] Write Protect is off -sd 0:0:0:0: [sda] No Caching mode page found -sd 0:0:0:0: [sda] Assuming drive cache: write through - sd 0:0:0:0: [sda] No Caching mode page found -/ +usb 2-1: new full-speed USB device number 3 using ci_hdrc +\ sd 0:0:0:0: [sda] Assuming drive cache: write through \ +sd 0:0:0:0: [sda] No Caching mode page found +- +sd 0:0:0:0: [sda] Assuming drive cache: write through +| sda: sda1 \ sd 0:0:0:0: [sda] No Caching mode page found -- +\ sd 0:0:0:0: [sda] Assuming drive cache: write through sd 0:0:0:0: [sda] Attached SCSI removable disk -- +\ cdc_acm 2-1:1.0: This device cannot do calls on its own. It is not a modem. -| +/ cdc_acm 2-1:1.0: ttyACM0: USB ACM device / usb 2-1: USB disconnect, device number 3 -| +/ usb 2-1: new full-speed USB device number 4 using ci_hdrc -\ +| usb 2-1: not running at top speed; connect to a high speed hub -done.VFS: Mounted root (ext2 filesystem) on device 1:0. +done. +VFS: Mounted root (ext2 filesystem) on device 1:0. devtmpfs: mounted Freeing unused kernel memory: 240K (c06b5000 - c06f1000) Mounting proc: done @@ -249,11 +252,10 @@ Cleaning up system: done Running local start scripts. Starting the hotplug events dispatcher udevd: done -Synthesizing the initial hotplug events:usb 2-1: unable to read config index 0 descriptor/all -usb 2-1: can't read configurations, error -110 -usb 2-1: new full-speed USB device number 5 using ci_hdrc +Synthesizing the initial hotplug events:usb 2-1: can't set config #1, error -110 done -usb 2-1: new full-speed USB device number 6 using ci_hdrc +usb 2-1: USB disconnect, device number 4 +usb 2-1: new full-speed USB device number 5 using ci_hdrc usb 2-1: not running at top speed; connect to a high speed hub cdc_acm 2-1:1.0: This device cannot do calls on its own. It is not a modem. cdc_acm 2-1:1.0: ttyACM0: USB ACM device @@ -284,10 +286,10 @@ Starting vinmonitor: done Starting Gateway application: Starting Console: done -Sync time from RTC: Sat Jan 22 07:40:24 UTC 2000 -Sat Jan 22 07:40:25 2000 -0.015364 seconds -Sat Jan 22 07:40:27 2000 -0.967175 seconds -Sat Jan 22 07:40:27 UTC 2000 +Sync time from RTC: Sat Jan 22 07:36:40 UTC 2000 +Sat Jan 22 07:36:42 2000 -0.924756 seconds +Sat Jan 22 07:36:44 2000 -0.998804 seconds +Sat Jan 22 07:36:44 UTC 2000 done microSD File system checking: e2fsck: Bad magic number in super-block while trying to open /dev/mmcblk0p1 (null):
error.zip |
at_koseki
2021年4月26日 18時37分
古関です。
> The superblock could not be read or does not describe a correct ext2 filesystem.
> If the device is valid and it really contains an ext2 filesystem (and not swap or ufs or something else),
> then the superblock is corrupt, and you might try running e2fsck with an alternate superblock: e2fsck -b 8193
正常系でも異常系でも
e2fsckでワーニングが出ていますが内容は確認したでしょうか?
ファイルシステムが破損していたりはしないでしょうか。
失敗するとはrc.local内のどこの処理で失敗するのでしょうか?
cpコマンドは成功したけど、実際に確認するとファイルがコピーされていないでしょうか。
例えば上記だと、check_statusは直前の一行の処理の結果しか判別しないように見え、
cpが失敗し、chmodが成功した場合OKになります。
古い/root/gateway/gw_cfg.txtが残っていた場合chmodは成功しますがチェック方法は問題ないでしょうか。
