Armadillo-840 システム停止
motoko_chen
2021年6月9日 11時39分
Armadillo-840基板を起動する時に、システムが停止してしまいました。
起動情報は下記となります。解決策をご教授頂きますよう宜しくお願い致します。
Hermit-At v3.11.0 (Armadillo-840/nor) compiled at 10:05:56, Sep 03 2020
Uncompressing kernel.....................................................................................................................................................................................done.
Uncompressing ramdisk.................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
ERROR: crc error
-- System halted
at_akihito.irie
2021年6月9日 18時05分
入江です。
本現象が発生する直前にArmadilloのユーザーランドを書き換えましたでしょうか。
書き換えたのであれば、そのイメージ自体か、書き換え時のコマンドなどが間
違えている可能性がありますので、そちらを見直してみてください。
入江様
いつもお世話になっております。
ご回答有難うございました。
イメージファイルが間違っているかと思いますが、
システムが起動できないので、正しいイメージファイルに変更できません。
どうしたらいいでしょか?ご教示頂きますよう宜しくお願い致します。
at_akihito.irie
2021年6月10日 12時57分
入江です。
Armadillo-840の製品マニュアルにイメージの書き換え手順が記されています。
https://manual.atmark-techno.com/armadillo-840/armadillo-840_product_ma…
今回の場合は、ブートローダーは起動できてカーネルは起動できていないので、
「ダウンローダーを使用する」または「TFTPを使用する」のどちらかの方法で
イメージを書き換えてください。
Armadillo-840とATDEが同一ネットワークに接続されているならば、tftpでの
書き換えの方が早いです。
