sai
2022年12月22日 17時39分
ゲートウェイコンテナイメージを改変してプログラムを追加しています。
mosquittoを入れようとしたのですがエラーとなっています。
/ # apk add mosquitto fetch https://download.atmark-techno.com/alpine/v3.16/atmark/armv7/APKINDEX.tar.gz ssse-flw: EmbSe_Init(): Entry App :INFO :Using PortName='/dev/i2c-1:0x48' (ENV: EX_SSS_BOOT_SSS_PORT=/dev/i2c-1:0x48) smCom :ERROR:Failed writing data (nrWritten=-1). smCom :ERROR: - Error in I2C Write..... smCom :ERROR:phNxpEseProto7816_SendRawFrame Error phNxpEse_WriteFrame smCom :ERROR:TransceiveProcess Transceive send failed, going to recovery! smCom :ERROR:phNxpEseProto7816_Open failed smCom :ERROR: Failed to Open session sss :ERROR:SM_I2CConnect Failed. Status 7012 App :ERROR:sss_session_open failed App :WARN :nxEnsure:'kStatus_SSS_Success == status' failed. At Line:352 Function:engineSessionOpen ssse-flw: EmbSe_Init(): Failed to initialize ssse-flw: Control Command EMBSE_LOG_LEVEL; requested log level = 4 ssse-err: Call to sss_rng_get_random failed ssse-err: Call to sss_rng_get_random failed Segmentation fault
apk updateも同様なので、何かが不足しているのでしょうか?
/ # apk update fetch https://download.atmark-techno.com/alpine/v3.16/atmark/armv7/APKINDEX.tar.gz ssse-flw: EmbSe_Init(): Entry App :INFO :Using PortName='/dev/i2c-1:0x48' (ENV: EX_SSS_BOOT_SSS_PORT=/dev/i2c-1:0x48) smCom :ERROR:Failed writing data (nrWritten=-1). smCom :ERROR: - Error in I2C Write..... smCom :ERROR:phNxpEseProto7816_SendRawFrame Error phNxpEse_WriteFrame smCom :ERROR:TransceiveProcess Transceive send failed, going to recovery! smCom :ERROR:phNxpEseProto7816_Open failed smCom :ERROR: Failed to Open session sss :ERROR:SM_I2CConnect Failed. Status 7012 App :ERROR:sss_session_open failed App :WARN :nxEnsure:'kStatus_SSS_Success == status' failed. At Line:352 Function:engineSessionOpen ssse-flw: EmbSe_Init(): Failed to initialize ssse-flw: Control Command EMBSE_LOG_LEVEL; requested log level = 4 ssse-err: Call to sss_rng_get_random failed ssse-err: Call to sss_rng_get_random failed Segmentation fault
sai
2022年12月22日 19時20分
ご回答ありがとうございます。
実行したところ以下のようになりました。
Permission denied が出ています。
/ # gpioset gpiochip3 18=1 / # apk update fetch https://download.atmark-techno.com/alpine/v3.16/atmark/armv7/APKINDEX.tar.gz ssse-flw: EmbSe_Init(): Entry App :INFO :Using PortName='/dev/i2c-1:0x48' (ENV: EX_SSS_BOOT_SSS_PORT=/dev/i2c-1:0x48) sss :INFO :atr (Len=35) 00 A0 00 00 03 96 04 03 E8 00 FE 02 0B 03 E8 08 01 00 00 00 00 64 00 00 0A 4A 43 4F 50 34 20 41 54 50 4F sss :WARN :Communication channel is Plain. sss :WARN :!!!Not recommended for production use.!!! ssse-flw: Version: 1.0.5 ssse-flw: EmbSe_Init(): Exit ssse-flw: Control Command EMBSE_LOG_LEVEL; requested log level = 4 3069567888:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:ssl/statem/statem_clnt.c:1919: ERROR: https://download.atmark-techno.com/alpine/v3.16/atmark: Permission denied WARNING: Ignoring https://download.atmark-techno.com/alpine/v3.16/atmark: No such file or directory fetch https://dl-cdn.alpinelinux.org/alpine/v3.16/main/armv7/APKINDEX.tar.gz 3069567888:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:ssl/statem/statem_clnt.c:1919: ERROR: https://dl-cdn.alpinelinux.org/alpine/v3.16/main: Permission denied WARNING: Ignoring https://dl-cdn.alpinelinux.org/alpine/v3.16/main: No such file or directory fetch https://dl-cdn.alpinelinux.org/alpine/v3.16/community/armv7/APKINDEX.tar.gz 3069567888:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:ssl/statem/statem_clnt.c:1919: ERROR: https://dl-cdn.alpinelinux.org/alpine/v3.16/community: Permission denied WARNING: Ignoring https://dl-cdn.alpinelinux.org/alpine/v3.16/community: No such file or directory 3 errors; 58 distinct packages available / #
よろしくお願い致します。
at_naomi.todori
2022年12月22日 19時58分
アットマークテクノの都鳥です。
こちらのフォーラムと同じ現象かと思います。
https://armadillo.atmark-techno.com/forum/armadillo/11427
恐れ入りますが、上記内容をご確認いただけますでしょうか?
sai
2022年12月26日 12時15分
ありがとうございます。
先方を確認しましたが、何をすれば良いのか分かりません。
armadillo:/etc/atmark# date Sat Jan 1 09:17:48 JST 2000 armadillo:/etc/atmark# chronyc sources MS Name/IP address Stratum Poll Reach LastRx Last sample ===============================================================================
NTPが設定されていないということでしょうか?
何処を設定すれば酔うのでしょうか?
コンテナ内ではなくホストOSの方で設定するのでしょうか?
ホストOSで設定したものはどのようにして永続化するのでしょうか?
理解が足りず申し訳ありませんが、よろしくお願い致します。
2022年12月26日 12時51分
saiさん
お世話になっています、
そうですね、デフォルトのコンフィグレーションは以下のはずですが、何かの理由で時間を上手く取得できてないように見えますね。
armadillo:~# cat /etc/chrony/conf.d/servers.conf # servers queried for normal operation pool pool.ntp.org iburst
> 何処を設定すれば酔うのでしょうか?
/etc/atmark/chrony.conf.d/servers.conf に自分のサーバーを設定すれば、そのファイルが優先されて運用しやすいと思います。
Armadillo IoT A6E の方のマニュアルに更新が入ってなかった申し訳ございません、時間の設定のところだけは Armadillo IoT G4 のマニュアルをご参照ください:
(お手数ですが、他は今まで通りに A6E のマニュアルを使ってください。この一部もこれから更新します。)
はい、ネットワークの接続に変更がある場合にも chronyd との連携が必要ですので、ホスト OS から取得しています。
/etc/atmark/chrony.conf.d/servers.conf を編集した後に persist_file /etc/atmark/chrony.conf.d/servers.conf
で保存してください。
/etc/atmark にあるファイルはアップデートの際に保存していますので、このファイルのための /etc/swupdate_preserve_files の更新が不要です。
よろしくお願いします
sai
2022年12月26日 13時36分
ご回答頂きありがとうございます。
マニュアルに従って登録してみましたがうまくいきませんでした。
armadillo:~# vi /etc/atmark/chrony.conf.d/servers.conf armadillo:~# persist_file /etc/atmark/chrony.conf.d/servers.conf [ 390.469149] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) armadillo:~# rc-service chronyd restart chronyd | * Stopping chronyd ... [ ok ] chronyd | * Starting chronyd ... [ ok ] armadillo:~# chronyc sources MS Name/IP address Stratum Poll Reach LastRx Last sample =============================================================================== armadillo:~#
「自分のサーバー」が分からなかったので「pool.ntp.org」と「ntp.nict.jp」を試してみましたがどちらも上記の結果となりました。
2022年12月26日 13時59分
「自分のサーバー」がなければ、デフォルトでもいいはずですね… この設定はネットワークのフィルターなどで外部のサーバーを使えないための物だと考えています。
解決した際に、このファイルを消しておいても問題ないと思いますが、このままでもいいです。(ファイル削除は persist_file -d <file>
で行えます)
その回答から考えるとこういう問題ではなさそうですので、改めて情報を確認させてください。
まずはコンフィグファイルの確認からです。以下のコマンドで、ファイルがデフォルトの内容と一致することを手短く確認します:
armadillo:~# sha256sum /etc/chrony/chrony.conf /etc/chrony/conf.d/* d5057e0acfe5ab8c5c3c73adae75c336448cff9bff6c9948f2175996980f2927 /etc/chrony/chrony.conf 36040fbe2fc868cae577c9fa29c7c0d8a6f1486933d9c782fee923cd046d4f80 /etc/chrony/conf.d/defaults.conf 98105c8ff87c9f450db50c0b14041c9761da75eb4cb0a7a01bcd1f5c5cfd94ea /etc/chrony/conf.d/initstepslew.conf 66617c7a46f8e4e51b9364a0893b3cbe3849373fc6a946a8cc8dc8d0a57ae5a4 /etc/chrony/conf.d/servers.conf
ハッシュか異なる場合があったら、そのファイルの内容を提供していただけたら幸いです。
その次は DNS の問題の可能性が高いと思います。
ホスト OS で ping -c 3 www.atmark-techno.com
を実行したら、どうなりますか?
こういう問題でしたら、DNS サーバーは自動的に DHCP で取得しているはずですが、ネットワーク設定を手動で行った場合には設定する必要もあります。
( https://manual.atmark-techno.com/armadillo-iot-a6e/armadillo-iotg-a6e_p… に nmcli connection modify [ID] ipv4.dns 192.0.2.1
の例が書いてあります、[ID]の取得は nmcli connection show
で表示できるはずです)
それ以外の問題は、とりあえず ping の結果を見てから考えたいと思います。
お手数をお掛けしますが、よろしくお願いします。
sai
2022年12月27日 8時45分
コンフィグファイルの確認は以下です。
armadillo:~# ping -c 3 www.atmark-techno.com ping: bad address 'www.atmark-techno.com'
IPアドレス固定の設定をしています。DHCPにはしていません。
https://armadillo.atmark-techno.com/forum/armadillo/13902
sai
2022年12月27日 9時15分
nmcli connection showの結果はこうなりmした。
NAME UUID TYPE DEVICE Ifupdown (eth0) 681b428f-beaf-8932-dce4-687ed5bae28e ethernet eth0 podman0 9775bb69-27e6-403a-bc24-8382964235a1 bridge podman0 vethbfd718bd e14d7a1e-bcb0-40a7-b097-ca4bb18b01de ethernet vethbfd718bd Wired connection 1 e4744a68-d19a-3602-baa3-506207a44031 ethernet --
NAMEが[ID]ということなのでIfupdown (eth0)かと思ったのですが以下のようになりました。
armadillo:~# nmcli connection modify "Ifupdown (eth0)" ipv4.dns 192.168.1.200 Error: Failed to modify connection 'Ifupdown (eth0)': failed to update connection: settings plugin does not support modifying connections
2022年12月27日 9時21分
saiさん
了解しました。別のスレッドで相談していましたね、把握しきれなくてすみません。
ping から「bad address」のエラーで DNS の設定の問題も確認しましたので、設定してみましょう。
nmcli を使ってなくて、/etc/network/interfaces 経由で設定を行っていますので、設定のところに「dns-nameserver server [server2]」の書き方になります。
以下の内容で ping も通るようになって、NTP もまた使えるようになると思います。
auto eth0 iface eth0 inet static address 192.168.1.190 netmask 255.255.255.0 gateway 192.168.1.1 dns-nameserver 192.168.1.1
設定した後に「nmcli c reload; nmcli con up "Ifupdown (eth0)"」で reload させると思いますが、できなかったら persist_file で保存して再起動してみてください。
同じタイミングで返事してくれましたね。「Failed to modify connection 'Ifupdown (eth0)': failed to update」のエラーは、/etc/network/interfaces の内容を nmcli で編集できないということです。 /etc/network/interfaces を使っていたことが分からなかったので、私の案内が悪かっただけですが、お手数をお掛けしました。申し訳ございませんが、dns-nameserver で試してみてください。
at_naomi.todori
2022年12月22日 18時35分
アットマークテクノの都鳥です。
セキュアエレメント SE050 が Enable になっていないことによるエラーです。
本件についてマニュアルの記載が漏れておりました。
ご迷惑をおかけし申し訳ございません。
取り急ぎの対応となり恐れ入りますが、
ゲートウェイコンテナの中で、以下コマンドの実行をお願いいたします。
ただし、Armadillo を reboot すると SE050 は Disable に戻ってしまうため、
Armadillo 起動後は毎回実行する必要があります。
回避方法については、また改めてこちらでお知らせさせていただきたいと思います。
どうぞ宜しくお願いいたします。
