satoshi.sa.aoki
2023年3月31日 11時20分
以下のように繰り返しコンソール上にログが出ているのですが以下のような症状の場合、何が起きているか等わかりますでしょうか?
WiFiルータとArmadillo間でWiFiの接続と切断が繰り返されているように見えますが、何が原因であるかなど。
wlan0: authenticate with 90:32:4b:fb:cc:5f wlan0: Wrong control channel: center-freq: 5660 ht-cfreq: 5180 ht->primary_chan: 36 band: 1 - Disabling HT wlan0: send auth to 90:32:4b:fb:cc:5f (try 1/3) wlan0: authenticated wlan0: associate with 90:32:4b:fb:cc:5f (try 1/3) wlan0: RX AssocResp from 90:32:4b:fb:cc:5f (capab=0x1131 status=0 aid=18) wlan0: associated nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based firewall rule not found. Use the iptables CT target to attach helpers instead. wlan0: deauthenticating from 90:32:4b:fb:cc:5f by local choice (Reason: 2=PREV_AUTH_NOT_VALID) wlan0: authenticate with 90:32:4b:fb:cc:5f wlan0: Wrong control channel: center-freq: 5660 ht-cfreq: 5180 ht->primary_chan: 36 band: 1 - Disabling HT wlan0: send auth to 90:32:4b:fb:cc:5f (try 1/3) wlan0: authenticated wlan0: associate with 90:32:4b:fb:cc:5f (try 1/3) wlan0: RX AssocResp from 90:32:4b:fb:cc:5f (capab=0x1131 status=0 aid=18) wlan0: associated wlan0: deauthenticating from 90:32:4b:fb:cc:5f by local choice (Reason: 2=PREV_AUTH_NOT_VALID) wlan0: authenticate with 90:32:4b:fb:cc:5f wlan0: Wrong control channel: center-freq: 5660 ht-cfreq: 5180 ht->primary_chan: 36 band: 1 - Disabling HT wlan0: send auth to 90:32:4b:fb:cc:5f (try 1/3) wlan0: authenticated wlan0: associate with 90:32:4b:fb:cc:5f (try 1/3) wlan0: RX AssocResp from 90:32:4b:fb:cc:5f (capab=0x1131 status=0 aid=18) wlan0: associated wlan0: deauthenticating from 90:32:4b:fb:cc:5f by local choice (Reason: 2=PREV_AUTH_NOT_VALID) wlan0: authenticate with 90:32:4b:fb:cc:5f wlan0: Wrong control channel: center-freq: 5660 ht-cfreq: 5180 ht->primary_chan: 36 band: 1 - Disabling HT wlan0: send auth to 90:32:4b:fb:cc:5f (try 1/3) wlan0: authenticated wlan0: associate with 90:32:4b:fb:cc:5f (try 1/3) wlan0: RX AssocResp from 90:32:4b:fb:cc:5f (capab=0x1131 status=0 aid=18) wlan0: associated
at_mizo
2023年4月4日 9時13分
溝渕です。
> Qualcomm Atheros製 AEH-AR9462になります。
ご回答ありがとうございます。
こちらで最新イメージで確認してみましたが、同様の現象は再現できませんでした。唯一極めて電波環境が悪い状態で接続リトライが繰り返す場合がありましたが、"Reason: 2=PREV_AUTH_NOT_VALID"というメッセージは確認できませんでした。
こちらで同様の現象が再現できましたら、解決に近づくと思いますのでいくつか質問させてください。
- 個体差はありますか?
-- 他のAPには接続できますか?
-- 他のArmadilloでも接続できませんか?
- ソフトウェアのバージョンはいくつですか?
- ソフトウェアのカスタマイズはしていますか?
- 2.4GHz帯のAPに接続可能ですか?
- APの設定を教えてください。
-- 暗号化方式, チャネル幅など
nko0012
2023年4月5日 17時36分
連絡遅れてしまい申し訳ございません、以下回答します(一部確認中のものや回答内容に自信がないものがありますので、お手数ですが合わせてご確認ください。)
- 個体差はありますか?
-- 他のAPには接続できますか?→できます。
-- 他のArmadilloでも接続できませんか?→こちら現在確認中です。分かり次第、ご連絡差し上げます。
- ソフトウェアのバージョンはいくつですか?→uImage-x1-v4.9-at28 になります。
- ソフトウェアのカスタマイズはしていますか?→カスタマイズはしておりません。
- 2.4GHz帯のAPに接続可能ですか?→可能です。
- APの設定を教えてください。→次のコマンドで実施しております(nmcli device wifi connect {SSID} password {パスワード})
-- 暗号化方式, チャネル幅など
暗号化方式:WPA2/WPA(PSK: AES)
チャネル幅:こちらはどのよう調べることができますでしょうか…慣れておらず申し訳ございません…
at_mizo
2023年4月12日 8時41分
溝渕です。
ご回答ありがとうございます。
一旦状況をまとめさせてください。
- 無線LANの接続と切断が繰り返されている
- 特定のArmadilloと、特定のAPでのみ問題が発生する
- 5GHz帯で接続した場合のみ問題が発生する
- ArmadilloまたはAPを替えると問題は発生しない
- Armadilloのソフトウェアは、現在最新のものを利用し、カスタマイズしていない(インストールディスク実行直後と同等の状況)
上記に誤認が無い場合は、個体不良の可能性が考えられます。お手数ですが、下記ページをご参照の上でご対応をお願いします。
nko0012
2023年4月13日 16時42分
こちら経過観察で状況変わったものもありますが、以下に回答記載します。
→Yes
→特定のArmadilloで発生:No(他の個体でも問題発生することを確認)
→特定のAPで発生:Yes
→Yes(同一ルータの2.4G㎐では問題発生していない)
→Armadilloを変えると発生しないか:No(他の個体でも問題発生することを確認)
→APを変えると発生しないか:Yes
→Yes
カーネル、DTB、U-Bootはアットマークテクノ様提供のまま
カーネルは最新のv4.9-at28を利用
ルートファイルシステムは独自のアプリやパッケージは入れているが、Wi-Fi接続は nmcli device wifi connect {SSID} password {パスワード}
であり、特別なことはしていない
at_mizo
2023年3月31日 11時41分
溝渕です。
以下と現象が似ていますね。
(私は同様の現象になった事が無いのでエラーログでWEB検索してみました)
https://askubuntu.com/questions/1450523/deauthenticated-reason-2-prev-a…
もし、2.4GHz/5GHzのESSIDを同一にして運用している場合は、変更してみていただけますか?
