sannguyen
2016年8月20日 10時56分
サンです。
いつもお世話になっております。
Armadillo-iot G3マニュアル”11. イメージファイルの書き換え方法” 通りにイメージファイルを書換えました。
今おかしい状態になってしまいました。何もしなくても自動的にリブート(reboot)することになっています。
armadillo-iotg login: root
Last login: Sat Aug 20 09:38:30 JST 2016 on ttymxc4
Linux armadillo-iotg 3.14.38-at2 #383 SMP PREEMPT Sun Jun 12 14:33:00 JST 2016 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
bash invoked oom-killer: gfp_mask=0x4d0, order=2, oom_score_adj=0
CPU: 1 PID: 1571 Comm: bash Not tainted 3.14.38-at2 #383
[<8001556c>] (unwind_backtrace) from [<80011604>] (show_stack+0x10/0x14)
[<80011604>] (show_stack) from [<80807f40>] (dump_stack+0x64/0xb4)
[<80807f40>] (dump_stack) from [<8080636c>] (dump_header.isra.10+0x64/0x198)
[<8080636c>] (dump_header.isra.10) from [<800a1f2c>] (oom_kill_process+0x354/0x3d0)
[<800a1f2c>] (oom_kill_process) from [<800a23e0>] (out_of_memory+0x26c/0x330)
[<800a23e0>] (out_of_memory) from [<800a6454>] (__alloc_pages_nodemask+0x8b8/0x8f8)
[<800a6454>] (__alloc_pages_nodemask) from [<800a64a4>] (__get_free_pages+0x10/0x24)
[<800a64a4>] (__get_free_pages) from [<8001b4ec>] (pgd_alloc+0x14/0x10c)
[<8001b4ec>] (pgd_alloc) from [<8003006c>] (mm_init.isra.49+0x90/0xcc)
[<8003006c>] (mm_init.isra.49) from [<80031394>] (copy_process+0xd74/0x12a8)
[<80031394>] (copy_process) from [<800319c8>] (do_fork+0x60/0x2c4)
[<800319c8>] (do_fork) from [<8000e420>] (ret_fast_syscall+0x0/0x30)
Mem-info:
DMA per-cpu:
CPU 0: hi: 6, btch: 1 usd: 0
CPU 1: hi: 6, btch: 1 usd: 0
active_anon:3313 inactive_anon:2178 isolated_anon:0
active_file:24 inactive_file:391 isolated_file:0
unevictable:0 dirty:0 writeback:0 unstable:0
free:79868 slab_reclaimable:885 slab_unreclaimable:2707
mapped:353 shmem:2261 pagetables:161 bounce:0
free_cma:76872
DMA free:319420kB min:2432kB low:3040kB high:3648kB active_anon:13252kB inactive_anon:o
lowmem_reserve[]: 0 0 0 0
DMA: 4804*4kB (EC) 4207*8kB (EMC) 2602*16kB (EC) 2048*32kB (C) 1273*64kB (C) 607*128kBB
2716 total pagecache pages
0 pages in swap cache
Swap cache stats: add 0, delete 0, find 0/0
Free swap = 0kB
Total swap = 0kB
98304 pages of RAM
80043 free pages
5182 reserved pages
2424 slab pages
137722 pages shared
0 pages swap cached
[ pid ] uid tgid total_vm rss nr_ptes swapents oom_score_adj name
[ 249] 0 249 2461 120 7 0 -1000 systemd-udevd
[ 270] 0 270 1843 362 8 0 0 systemd-journal
[ 394] 0 394 948 60 4 0 0 bluetoothd
[ 395] 0 395 1633 114 6 0 -1000 sshd
[ 399] 0 399 9844 251 15 0 0 ModemManager
[ 401] 0 401 12858 413 16 0 0 NetworkManager
[ 402] 0 402 712 49 5 0 0 cron
[ 406] 0 406 772 62 5 0 0 systemd-logind
[ 409] 105 409 820 75 5 0 0 avahi-daemon
[ 410] 104 410 1181 116 6 0 -900 dbus-daemon
[ 419] 105 419 789 54 5 0 0 avahi-daemon
[ 453] 0 453 7848 236 9 0 0 rsyslogd
[ 525] 33 525 1625 172 6 0 0 lighttpd
[ 544] 0 544 8647 155 11 0 0 polkitd
[ 655] 0 655 758 29 5 0 0 agetty
[ 693] 0 693 1362 113 5 0 0 wpa_supplicant
[ 703] 106 703 2013 127 6 0 0 exim4
[ 1517] 0 1517 1226 110 5 0 0 login
[ 1528] 0 1528 930 82 6 0 0 systemd
[ 1534] 0 1534 6056 305 10 0 0 (sd-pam)
[ 1542] 0 1542 1109 471 6 0 0 bash
[ 1571] 0 1571 1109 472 6 0 0 bash
Out of memory: Kill process 1571 (bash) score 4 or sacrifice child
Killed process 1571 (bash) total-vm:4436kB, anon-rss:1888kB, file-rss:0kB
bash: page allocation failure: order:2, mode:0x4d0
[<80807f40>] (dump_stack) from [<800a35b0>] (warn_alloc_failed+0xcc/0x10c)
[<800a35b0>] (warn_alloc_failed) from [<800a61cc>] (__alloc_pages_nodemask+0x630/0x8f8)
[<800a61cc>] (__alloc_pages_nodemask) from [<800a64a4>] (__get_free_pages+0x10/0x24)
Mem-info:
DMA per-cpu:
active_anon:3325 inactive_anon:2178 isolated_anon:0
active_file:55 inactive_file:416 isolated_file:0
unevictable:0 dirty:6 writeback:0 unstable:0
free:79834 slab_reclaimable:885 slab_unreclaimable:2707
mapped:383 shmem:2261 pagetables:166 bounce:0
free_cma:76888
DMA free:319336kB min:2432kB low:3040kB high:3648kB active_anon:13300kB inactive_anon:o
DMA: 4804*4kB (EC) 4189*8kB (EMC) 2601*16kB (C) 2048*32kB (C) 1273*64kB (C) 607*128kB B
2743 total pagecache pages
Free swap = 0kB
Total swap = 0kB
98304 pages of RAM
80002 free pages
5182 reserved pages
2424 slab pages
203272 pages shared
0 pages swap cached
CPU: 1 PID: 1573 Comm: bash Not tainted 3.14.38-at2 #383
[<8003006c>] (mm_init.isra.49) from [<800dee8c>] (do_execve+0x194/0x4d0)
[<800dee8c>] (do_execve) from [<8000e420>] (ret_fast_syscall+0x0/0x30)
省略
今出荷状態に戻したいですが、マニュアルに詳しく書いてないので、よろしくお願いします。
at_mizo
溝渕です。
> atmark@atde6:~/linux-3.14.38-at2$ ln -s ../initramfs_x1-v1.0.0.cpio.gz
initramfsアーカイブの名称は、"initramfs_x1.cpio.gz"である必要がありま
す。上記のようにコマンドを実行してしまうと、Linuxカーネルがinitramfsアー
カイブを見付けられないため、
> /home/atmark/linux-3.14.38-at2/scripts/gen_initramfs_list.sh: Cannot open 'initramfs_x1.cpio.gz'
のようにエラーが発生しています。
http://manual.atmark-techno.com/armadillo-iot-g3/armadillo-iotg-g3_prod…
に記載されている、
「2. initramfsアーカイブへのシンボリックリンク作成」
を参考にして、シンボリックリンクを作成してください。
atmark@atde6:~/linux-3.14.38-at2$ ln -s ../initramfs_x1-v1.0.0.cpio.gz initramfs_x1.cpio.gz
のようになります。
以上です。
sannguyen
溝渕様、
サンです。宜しくお願いします。
出荷状態に戻したいので、マニュアルの11.1.1.インストールデイスクの作成通りやりました。
Log:
atmark@atde6:~/download$ sudo umount /dev/sdc1
atmark@atde6:~/download$ sudo dd if=install_disk_sd_20160705.img of=/dev/sdc bs=4M
90+1 レコード入力
90+1 レコード出力
380633600 バイト (381 MB) コピーされました、 138.13 秒、 2.8 MB/秒
atmark@atde6:~/download$ sync
更にArmadillo に電源を投入する時、次の様に表示されていました。
Log:
U-Boot 2014.04-at2 (Jun 12 2016 - 17:47:04)
CPU: Freescale i.MX7D rev1.1 at 792 MHz
CPU: Temperature: can't get valid data!
Reset cause: POR
I2C: ready
Board Type: Armadillo-IoT G3(0a000000)
Revison: 0002
S/N: 2261
DRAM: 00001d05
XTAL: 00
Net: FEC0
mmc0 is current device
reading boot.scr
reading uImage
9301216 bytes read in 474 ms (18.7 MiB/s)
reading armadillo_iotg_g3.dtb
52708 bytes read in 22 ms (2.3 MiB/s)
Image Name: Linux-3.14.38-at2
Data Size: 9301152 Bytes = 8.9 MiB
Load Address: 80008000
Entry Point: 80008000
Loading Kernel Image ... OK
Using Device Tree in place at 83000000, end 8300fde3
Linux version 3.14.38-at2 (ohsawa@pc-sienta) (gcc version 4.6.3 (Debian 4.6.3-14atmark6
CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
Machine model: Atmark-Techno Armadillo-IoT Gateway G3 Board
cma: CMA: reserved 320 MiB at 8c000000
Memory policy: Data cache writealloc
PERCPU: Embedded 8 pages/cpu @8bb35000 s8256 r8192 d16320 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
Kernel command line: console=ttymxc4,115200 root=/dev/mmcblk0p2 rootwait rw
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 172316K/524288K available (8487K kernel code, 504K rwdata, 6948K rodata, 2540K)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xa0800000 - 0xff000000 (1512 MB)
lowmem : 0x80000000 - 0xa0000000 ( 512 MB)
pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
.text : 0x80008000 - 0x80f1af20 (15436 kB)
.init : 0x80f1b000 - 0x81196040 (2541 kB)
.data : 0x81198000 - 0x81216360 ( 505 kB)
.bss : 0x8121636c - 0x81284724 ( 441 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
Switching to timer-based delay loop
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655765682ns
Architected cp15 timer(s) running at 8.00MHz (phys).
sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2147483648000ns
Ignoring duplicate/late registration of read_current_timer delay
Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMI)
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
/cpus/cpu@0 missing clock-frequency property
/cpus/cpu@1 missing clock-frequency property
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x8080e648 - 0x8080e6a0
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (12.00 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
regulator-dummy: no parameters
cpuidle: using governor ladder
cpuidle: using governor menu
Use WDOG1 as reset source
GPIO line 13 (MCU_INTB) hogged as input
GPIO line 43 (SVEN) hogged as output/high
GPIO line 85 (3G_VUSB_IN) hogged as output/high
GPIO line 113 (3G_IGT_3.3) hogged as output/high
syscon 30340000.iomuxc-gpr: regmap [mem 0x30340000-0x3034ffff] registered
syscon 30350000.ocotp-ctrl: regmap [mem 0x30350000-0x3035ffff] registered
syscon 30360000.anatop: regmap [mem 0x30360000-0x3036ffff] registered
vdd1p0d: 800 <--> 1200 mV at 1000 mV
vdd1p2: 1100 <--> 1300 mV
syscon 30390000.src: regmap [mem 0x30390000-0x3039ffff] registered
DDR type is DDR3!
prom_parse: Bad cell count for /regulators0/regulator@0
hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 8 bytes.
imx7d-pinctrl 302c0000.iomuxc-lpsr: initialized IMX pinctrl driver
imx7d-pinctrl 30330000.iomuxc: Invalid fsl,pins property in node /soc/aips-bus@3000000p
imx7d-pinctrl 30330000.iomuxc: initialized IMX pinctrl driver
MU is ready for cross core communication!
bio: create slab at 0
mxs-dma 33000000.dma-apbh: initialized
USB_OTG1_VBUS: 5000 mV
VDD_SD1: 3300 mV
vgaarb: loaded
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
SCSI subsystem initialized
30800000.aips-bus:usbphy_nop1 supply vcc not found, using dummy regulator
30800000.aips-bus:usbphy_nop2 supply vcc not found, using dummy regulator
i2c i2c-0: IMX I2C adapter registered
gpio_bmic 3-0014: version: 1.0
bmic_regulator 3-0016: version: 1.0
BMIC_VREF: 1710 <--> 3600 mV at 2965 mV
i2c i2c-3: IMX I2C adapter registered
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti
PTP clock support registered
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.18
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
cfg80211: Calling CRDA to update world regulatory domain
armadillo_iotg_addon addon: Atmark Techno RS232C board detected at CON1(Rev 2, SerialN.
armadillo_iotg_addon addon: No add-on expansion board detected at CON2.
Switched to clocksource arch_sys_counter
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
imx rpmsg driver is registered.
Bus freq driver module loaded
futex hash table entries: 512 (order: 3, 32768 bytes)
VFS: Disk quotas dquot_6.5.2
Key type id_resolver registered
Key type id_legacy registered
jffs2: version 2.2. (NAND) �� 2001-2006 Red Hat, Inc.
fuse init (API version 7.22)
msgmni has been set to 976
io scheduler noop registered
imx-sdma 30bd0000.sdma: no event needs to be remapped
imx-sdma 30bd0000.sdma: loaded firmware 4.1
imx-sdma 30bd0000.sdma: initialized
pfuze100-regulator 3-0009: Full layer: 1, Metal layer: 1
pfuze100-regulator 3-0009: FAB: 0, FIN: 0
pfuze100-regulator 3-0009: pfuze3000 found.
SW1A: 700 <--> 1475 mV at 1100 mV
SW1B: 700 <--> 1475 mV at 1000 mV
SW2: 1500 <--> 1850 mV at 1800 mV
SW3: 900 <--> 1650 mV at 1350 mV
SWBST: 5000 <--> 5150 mV at 5000 mV
VSNVS: 1000 <--> 3000 mV at 3000 mV
VREFDDR: 750 mV
VLDO1: 1800 <--> 3300 mV at 1800 mV
VLDO2: 800 <--> 1550 mV at 1500 mV
VCCSD: 2850 <--> 3300 mV at 3300 mV
V33: 2850 <--> 3300 mV at 3300 mV
VLDO3: 1800 <--> 3300 mV at 3300 mV
VLDO4: 1800 <--> 3300 mV at 3300 mV
30a70000.serial: ttymxc4 at MMIO 0x30a70000 (irq = 62, base_baud = 1500000) is a IMX
console [ttymxc4] enabled
30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 58, base_baud = 1500000) is a IMX
serial: Freescale lpuart driver
imx sema4 driver is registered.
[drm] Initialized drm 1.1.0 20060810
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
fsl-quadspi 30bb0000.qspi: Unsupported cmd 0x65
fsl-quadspi 30bb0000.qspi: Unsupported cmd 0x61
fsl-quadspi 30bb0000.qspi: n25q064 (8192 Kbytes)
3 ofpart partitions found on MTD device 30bb0000.qspi
Creating 3 MTD partitions on "30bb0000.qspi":
0x000000000000-0x000000100000 : "bootloader"
0x000000100000-0x000000140000 : "license"
0x000000140000-0x000000800000 : "reserved"
fsl-quadspi 30bb0000.qspi: QuadSPI SPI NOR flash driver
CAN device driver interface
30bf0000.ethernet supply phy not found, using dummy regulator
pps pps0: new PPS source ptp0
libphy: fec_enet_mii_bus: probed
fec 30bf0000.ethernet eth0: registered PHC device 0
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver cdc_eem
usbcore: registered new interface driver sierra_net
usbcore: registered new interface driver qmi_wwan
ehci-pci: EHCI PCI platform driver
ehci-mxc: Freescale On-Chip EHCI Host driver
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new interface driver cdc_wdm
usbcore: registered new interface driver option
usbserial: USB Serial support registered for GSM modem (1-port)
usbserial: USB Serial support registered for Sierra USB modem
usbcore: registered new interface driver usb_serial_simple
usbserial: USB Serial support registered for zio
usbserial: USB Serial support registered for funsoft
usbserial: USB Serial support registered for flashloader
usbserial: USB Serial support registered for vivopay
usbserial: USB Serial support registered for moto_modem
usbserial: USB Serial support registered for hp4x
usbserial: USB Serial support registered for suunto
usbserial: USB Serial support registered for siemens_mpi
usb3503 3-0008: switched to HUB mode
usb3503 3-0008: usb3503_probe: probed in hub mode
30b10200.usbmisc supply vbus-wakeup not found, using dummy regulator
30b20200.usbmisc supply vbus-wakeup not found, using dummy regulator
30b30200.usbmisc supply vbus-wakeup not found, using dummy regulator
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
30b30000.usb supply vbus not found, using dummy regulator
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
input: 30370000.snvs-pwrkey as /devices/soc/30000000.aips-bus/30370000.snvs-pwrkey/inp0
snvs_pwrkey 30370000.snvs-pwrkey: i.MX snvs powerkey probed
i2c-core: driver [isl29023] using legacy suspend method
i2c-core: driver [isl29023] using legacy resume method
bmic_rtc 3-0011: version: 1.0
bmic_rtc 3-0011: rtc core: registered bmic_rtc as rtc0
snvs_rtc 30370034.snvs-rtc-lp: rtc core: registered 30370034.snvs-rtc-l as rtc1
i2c /dev entries driver
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR RC5 (streamzap) protocol handler initialized
IR SANYO protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
i2c-core: driver [mag3110] using legacy suspend method
i2c-core: driver [mag3110] using legacy resume method
bmic_thermal 3-0013: version: 1.0
imx2-wdt 30280000.wdog: timeout 10 sec (nowayout=0)
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCI H4 protocol initialized
Bluetooth: HCI BCSP protocol initialized
Bluetooth: HCIATH3K protocol initialized
usbcore: registered new interface driver bcm203x
usbcore: registered new interface driver btusb
usbcore: registered new interface driver ath3k
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: no vqmmc regulator found
mmc0: SDHCI controller on 30b40000.usdhc [30b40000.usdhc] using ADMA
sdhci-esdhc-imx 30b60000.usdhc: could not get ultra high speed state, work on normal me
mmc2: no vqmmc regulator found
mmc2: no vmmc regulator found
usb 1-1: new high-speed USB device number 2 using ci_hdrc
mmc2: SDHCI controller on 30b60000.usdhc [30b60000.usdhc] using ADMA
mmc0: new high speed SDHC card at address 0007
mmcblk0: mmc0:0007 SW04G 3.70 GiB
mmcblk0: p1 p2 p3
caam 30900000.caam: Instantiated RNG4 SH0
caam 30900000.caam: Instantiated RNG4 SH1
caam 30900000.caam: device ID = 0x0a160300 (Era 8)
caam 30900000.caam: job rings = 3, qi = 0
mmc2: BKOPS_EN bit is not set
usb-storage 1-1:1.0: USB Mass Storage device detected
scsi0 : usb-storage 1-1:1.0
mmc2: new high speed DDR MMC card at address 0001
mmcblk2: mmc2:0001 Q1J55L 3.56 GiB
mmcblk2boot0: mmc2:0001 Q1J55L partition 1 2.00 MiB
mmcblk2boot1: mmc2:0001 Q1J55L partition 2 2.00 MiB
mmcblk2rpmb: mmc2:0001 Q1J55L partition 3 4.00 MiB
mmcblk2: p1 p2 p3
mmcblk2boot1: unknown partition table
mmcblk2boot0: unknown partition table
caam algorithms registered in /proc/crypto
caam_jr 30901000.jr0: registering rng-caam
snvs-secvio 30370000.caam-snvs: violation handlers armed - non-secure state
usbhid: USB HID core driver
usbcore: registered new interface driver r8712u
bmic_adc 3-0012: version: 1.0
coresight-tmc 30086000.etr: TMC initialized
coresight-tmc 30084000.etf: TMC initialized
usb 2-1: new high-speed USB device number 2 using ci_hdrc
coresight-tpiu 30087000.tpiu: TPIU initialized
coresight-funnel 30083000.funnel: FUNNEL initialized
coresight-funnel 30041000.funnel: FUNNEL initialized
coresight-replicator replicator: REPLICATOR initialized
coresight-etm3x 3007c000.etm: ETM initialized
coresight-etm3x 3007d000.etm: ETM initialized
NET: Registered protocol family 26
nf_conntrack version 0.5.0 (7812 buckets, 31248 max)
ipip: IPv4 over IPv4 tunneling driver
gre: GRE over IPv4 demultiplexor driver
ip_gre: GRE over IPv4 tunneling driver
TCP: cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 10
mip6: Mobile IPv6
ip6_tables: (C) 2000-2006 Netfilter Core Team
sit: IPv6 over IPv4 tunneling driver
ip6_gre: GRE over IPv6 tunneling driver
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
8021q: 802.1Q VLAN Support v1.8
Key type dns_resolver registered
cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)
hub 2-1:1.0: USB hub found
hub 2-1:1.0: 3 ports detected
imx6q-pcie 33800000.pcie: PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [io 0x1000-0x10000]
pci_bus 0000:00: root bus resource [mem 0x40000000-0x4fefffff]
pci_bus 0000:00: root bus resource [bus 00-ff]
PCI: bus0: Fast back to back transfers disabled
PCI: bus1: Fast back to back transfers disabled
pci 0000:00:00.0: BAR 0: assigned [mem 0x40000000-0x400fffff]
pci 0000:00:00.0: BAR 14: assigned [mem 0x40100000-0x401fffff]
pci 0000:00:00.0: BAR 15: assigned [mem 0x40200000-0x402fffff pref]
pci 0000:00:00.0: BAR 6: assigned [mem 0x40300000-0x4030ffff pref]
pci 0000:01:00.0: BAR 0: assigned [mem 0x40100000-0x4017ffff 64bit]
pci 0000:01:00.0: BAR 6: assigned [mem 0x40200000-0x4020ffff pref]
pci 0000:00:00.0: PCI bridge to [bus 01]
pci 0000:00:00.0: bridge window [mem 0x40100000-0x401fffff]
pci 0000:00:00.0: bridge window [mem 0x40200000-0x402fffff pref]
pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
PCI: enabling device 0000:01:00.0 (0140 -> 0142)
ieee80211 phy0: Atheros AR9462 Rev:2 mem=0xa0b00000, irq=157
regulator-dummy: disabling
imx mcc test is registered.
input: gpio-keys as /devices/gpio-keys/input/input1
bmic_rtc 3-0011: setting system clock to 1970-01-01 00:00:04 UTC (4)
usb 2-1.3: new full-speed USB device number 3 using ci_hdrc
ALSA device list:
No soundcards found.
Warning: unable to open an initial console.
Freeing unused kernel memory: 2540K (80f1b000 - 81196000)
systemd-udevd[164]: starting version 215
random: systemd-udevd urandom read with 43 bits of entropy available
usb 2-1.3: string descriptor 0 read error: -22
usb 2-1.3: USB disconnect, device number 3
scsi 0:0:0:0: Direct-Access GH PicoN PMAP PQ: 0 ANSI: 0 CCS
usb 2-1.3: new full-speed USB device number 4 using ci_hdrc
kjournald starting. Commit interval 5 seconds
EXT3-fs (mmcblk0p2): using internal journal
EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
sd 0:0:0:0: [sda] 1959936 512-byte logical blocks: (1.00 GB/957 MiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] No Caching mode page found
sd 0:0:0:0: [sda] Assuming drive cache: write through
sda: sda1
sd 0:0:0:0: [sda] Attached SCSI removable disk
usb 2-1.2: new high-speed USB device number 5 using ci_hdrc
random: nonblocking pool is initialized
cdc_acm 2-1.2:1.0: ttyACM0: USB ACM device
cdc_acm 2-1.2:1.2: ttyACM1: USB ACM device
cdc_acm 2-1.2:1.4: ttyACM2: USB ACM device
cdc_acm 2-1.2:1.6: ttyACM3: USB ACM device
cdc_acm 2-1.2:1.11: ttyACM4: USB ACM device
cdc_acm 2-1.2:1.13: ttyACM5: USB ACM device
Mounting proc: failed
Starting fsck for root filesystem.
fsck 1.25 (20-Sep-2001)
/dev/mmcblk0p2: clean, 1049/5136 files, 19032/20480 blocks
Checking root filesystem: done
Remounting root rw: EXT3-fs (mmcblk0p2): using internal journal
done
Mounting sysfs: failed
Mounting tmpfs on /dev: done
Cleaning up system: done
Running local start scripts.
Creating mtd devnode: done
Starting udevd: done
Mounting devpts: done
Changing file permissions: done
Configure /home/ftp: done
Starting syslogd: done
Starting klogd: done
Mounting tmpfs on /tmp, /var/tmp: done
Mounting ramfs on /home/ftp/pub: done
Setting hostname: done
Starting inetd: done
Running local start script (/etc/config/rc.local).
EXT3-fs (mmcblk0p3): using internal journal
EXT3-fs (mmcblk0p3): mounted filesystem with ordered data mode
*+*+* Recovery Start!! *+*+*
=== Step.1 Setup SPI Flash ===
/mnt/u-boot-x1-at2.bin: OK
=== Step.2 Formatting eMMC ===
The number of cylinders for this disk is set to 116736.
(e.g., DOS FDISK, OS/2 FDISK)
Command (m for help): Building a new DOS disklabel. Changes will remain in memory only,
until you decide to write them. After that the previous content
won't be recoverable.
Command (m for help): Command action
e extended
p primary partition (1-4)
Partition number (1-4): First cylinder (1-116736, default 1): Using default value 1
Last cylinder or +size or +sizeM or +sizeK (1-116736, default 116736):
e extended
Partition number (1-4): First cylinder (979-116736, default 979): Using default value 9
Last cylinder or +size or +sizeM or +sizeK (979-116736, default 116736):
e extended
Partition number (1-4): First cylinder (1957-116736, default 1957): Using default valu7
Last cylinder or +size or +sizeM or +sizeK (1957-116736, default 116736): Using defaul6
Command (m for help): Command (m for help): Partition number (1-4): Hex code (type L t)
Command (m for help): Partition number (1-4): Hex code (type L to list codes):
Command (m for help): The partition table has been altered.
Calling ioctl() to re-read partition table
mmcblk2: p1 p2 p3
mkfs.vfat 2.11 (12 Mar 2005)
Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
Stride=0 blocks, Stripe width=0 blocks
229680 inodes, 918240 blocks
45912 blocks (5.00%) reserved for the super user
First data block=0
Maximum filesystem blocks=943718400
29 block groups
32768 blocks per group, 32768 fragments per group
7920 inodes per group
Allocating group tables: done
Writing inode tables: done
Disk /dev/mmcblk2: 3825 MB, 3825205248 bytes
4 heads, 16 sectors/track, 116736 cylinders
Units = cylinders of 64 * 512 = 32768 bytes
Device Boot Start End Blocks Id System
/dev/mmcblk2p1 1 978 31288 b Win95 FAT32
/dev/mmcblk2p2 1957 116736 3672960 83 Linux
/dev/mmcblk2p3 979 1956 31296 83 Linux
Partition table entries are not in disk order
=== Step.3 Setup Partition ===
/mnt/debian-jessie-armhf_aiotg3_20160705.tar.gz: OK
EXT4-fs (mmcblk2p2): mounted filesystem with ordered data mode. Opts: (null)
/mnt/uImage-x1-v2.00: OK
/mnt/armadillo_iotg_g3-v2.00.dtb: OK
=== Step.4 sync ===
*+*+* Recovery Completed!! *+*+*
System is going down for system reboot now.
Starting local stop scripts.
Syncing all filesystems: done
Unmounting all filesystems: done
imx2-wdt 30280000.wdog: Device shutdown: Expect reboot!
reboot: System halted
気になるところは
省略
reading boot.scr
** Unable to read file boot.scr ** <==気になるところです。
省略
Mounting proc: failed <==気になるところです。
done
Mounting sysfs: failed <==気になるところです。
省略
<==気になるところです。”The system is going down NOW!
Requesting system halt”が書いてありますか。
後で、リブートし、Armadilloの状態がおかしかったです。
何回も自動的にログイン画面が表示されました。
Log:
省略
0 pages swap cached
[ 255] 0 255 2461 116 6 0 -1000 systemd-udevd
[ 270] 0 270 1843 175 7 0 0 systemd-journal
[ 392] 0 392 948 60 4 0 0 bluetoothd
[ 394] 0 394 12861 413 16 0 0 NetworkManager
[ 395] 0 395 712 46 4 0 0 cron
[ 396] 0 396 9879 262 13 0 0 ModemManager
[ 403] 0 403 772 56 5 0 0 systemd-logind
[ 405] 105 405 820 70 5 0 0 avahi-daemon
[ 407] 104 407 1181 116 6 0 -900 dbus-daemon
[ 427] 105 427 789 54 5 0 0 avahi-daemon
[ 454] 0 454 7848 187 9 0 0 rsyslogd
[ 490] 0 490 570 32 5 0 0 systemd-hostnam
[ 494] 0 494 8765 249 11 0 0 polkitd
[ 531] 33 531 1625 163 6 0 0 lighttpd
[ 684] 0 684 1362 101 5 0 0 wpa_supplicant
[ 688] 0 688 758 29 5 0 0 agetty
[ 690] 0 690 1226 110 5 0 0 login
[ 700] 106 700 2013 127 7 0 0 exim4
[ 709] 0 709 1942 1173 6 0 0 dhclient
[ 762] 0 762 938 81 6 0 0 systemd
[ 768] 0 768 1430 272 5 0 0 (sd-pam)
[ 776] 0 776 1781 1145 7 0 0 bash
[ 864] 0 864 2687 174 9 0 0 pppd
[ 889] 0 889 4522 138 9 0 0 nm-dispatcher
[ 893] 0 893 358 17 3 0 0 01ifupdown
[ 927] 0 927 358 20 2 0 0 ntpdate
[ 931] 0 931 351 14 3 0 0 lockfile-touch
[ 932] 0 932 760 71 5 0 0 ntpdate
[ 938] 0 938 341 19 4 0 0 run-parts
[ 940] 0 940 358 20 3 0 0 avahi-daemon-ch
[ 944] 0 944 358 21 3 0 0 avahi-daemon-ch
[ 945] 0 945 358 21 3 0 0 avahi-daemon-ch
[ 946] 0 946 517 133 4 0 0 grep
Out of memory: Kill process 709 (dhclient) score 12 or sacrifice child
Killed process 709 (dhclient) total-vm:7768kB, anon-rss:4692kB, file-rss:0kB
avahi-daemon-ch invoked oom-killer: gfp_mask=0x4d0, order=2, oom_score_adj=0
CPU: 0 PID: 986 Comm: avahi-daemon-ch Not tainted 3.14.38-at2 #383
Mem-info:
DMA per-cpu:
active_anon:4471 inactive_anon:2179 isolated_anon:0
active_file:22 inactive_file:235 isolated_file:0
free:79477 slab_reclaimable:883 slab_unreclaimable:3146
mapped:103 shmem:2264 pagetables:196 bounce:0
free_cma:76736
DMA free:317908kB min:2432kB low:3040kB high:3648kB active_anon:17884kB inactive_anon:s
DMA: 5145*4kB (EC) 5280*8kB (EMC) 4286*16kB (C) 2114*32kB (C) 1277*64kB (C) 251*128kB B
2683 total pagecache pages
Free swap = 0kB
Total swap = 0kB
98304 pages of RAM
79408 free pages
5182 reserved pages
2182 slab pages
202299 pages shared
0 pages swap cached
[ 270] 0 270 1843 174 7 0 0 systemd-journal
[ 394] 0 394 12861 415 16 0 0 NetworkManager
[ 405] 105 405 820 101 5 0 0 avahi-daemon
[ 407] 104 407 1181 118 6 0 -900 dbus-daemon
[ 531] 33 531 1625 167 6 0 0 lighttpd
[ 889] 0 889 4522 140 9 0 0 nm-dispatcher
[ 969] 0 969 358 20 3 0 0 ntpdate
[ 971] 0 971 351 14 4 0 0 lockfile-create
[ 977] 0 977 358 12 3 0 0 01ifupdown
[ 978] 0 978 341 19 4 0 0 run-parts
[ 982] 0 982 358 20 3 0 0 avahi-daemon-ch
[ 986] 0 986 358 20 3 0 0 avahi-daemon-ch
Out of memory: Kill process 776 (bash) score 12 or sacrifice child
Killed process 776 (bash) total-vm:7124kB, anon-rss:4580kB, file-rss:0kB
Debian GNU/Linux 8 armadillo-iotg ttymxc4
Last login: Thu Jan 1 09:00:21 JST 1970 on ttymxc4
何回もsdカードをbootable b w95 fat32にフォーマットし、インストールデイスクを作成し、やり直しましたが
結果としては同じです。11.2.特定のイメージファイルだけを書換える通りやってみましたが、治りませんでした。
但し、15.SDブートの活用通りにSDカードで起動したら、OSがうまく動きました。
どうやったら出荷状態に戻せるのかご教示いただけないでしょうか。
sannguyen
2016年8月20日 17時33分
サンです。
いつもお世話になっております。
10.ビルド手順通りやりましたが、エラーが発生してしまいました。
10.2.Linux カーネルをビルドする
atmark@atde6:~$ ls
code initramfs_x1-v1.0.0.cpio.gz linux-3.14.38-at2.tar.gz ダウンロード ドキュメント 画像
core library minicom.log テンプレート ビデオ 公開
demo linux-3.14.38-at2 san-project デスクトップ 音楽
atmark@atde6:~$ tar xf linux-3.14.38-at2.tar.gz
atmark@atde6:~$ cd linux-3.14.38-at2/
atmark@atde6:~/linux-3.14.38-at2$ make ARCH=arm x1_defconfig
HOSTCC scripts/basic/fixdep
HOSTCC scripts/kconfig/conf.o
SHIPPED scripts/kconfig/zconf.tab.c
SHIPPED scripts/kconfig/zconf.lex.c
SHIPPED scripts/kconfig/zconf.hash.c
HOSTCC scripts/kconfig/zconf.tab.o
HOSTLD scripts/kconfig/conf
atmark@atde6:~/linux-3.14.38-at2$ make CROSS_COMPILE=arm-linux-gnueabihf- ARCH=arm
scripts/kconfig/conf --silentoldconfig Kconfig
CHK include/config/kernel.release
UPD include/config/kernel.release
WRAP arch/arm/include/generated/asm/auxvec.h
WRAP arch/arm/include/generated/asm/bitsperlong.h
WRAP arch/arm/include/generated/asm/cputime.h
WRAP arch/arm/include/generated/asm/current.h
WRAP arch/arm/include/generated/asm/emergency-restart.h
WRAP arch/arm/include/generated/asm/errno.h
WRAP arch/arm/include/generated/asm/exec.h
WRAP arch/arm/include/generated/asm/ioctl.h
WRAP arch/arm/include/generated/asm/ipcbuf.h
WRAP arch/arm/include/generated/asm/irq_regs.h
WRAP arch/arm/include/generated/asm/kdebug.h
WRAP arch/arm/include/generated/asm/local.h
WRAP arch/arm/include/generated/asm/local64.h
WRAP arch/arm/include/generated/asm/msgbuf.h
WRAP arch/arm/include/generated/asm/param.h
WRAP arch/arm/include/generated/asm/parport.h
WRAP arch/arm/include/generated/asm/poll.h
WRAP arch/arm/include/generated/asm/resource.h
WRAP arch/arm/include/generated/asm/sections.h
WRAP arch/arm/include/generated/asm/segment.h
WRAP arch/arm/include/generated/asm/sembuf.h
WRAP arch/arm/include/generated/asm/serial.h
WRAP arch/arm/include/generated/asm/shmbuf.h
WRAP arch/arm/include/generated/asm/siginfo.h
WRAP arch/arm/include/generated/asm/simd.h
WRAP arch/arm/include/generated/asm/sizes.h
WRAP arch/arm/include/generated/asm/socket.h
WRAP arch/arm/include/generated/asm/sockios.h
WRAP arch/arm/include/generated/asm/termbits.h
WRAP arch/arm/include/generated/asm/termios.h
WRAP arch/arm/include/generated/asm/timex.h
WRAP arch/arm/include/generated/asm/trace_clock.h
WRAP arch/arm/include/generated/asm/unaligned.h
WRAP arch/arm/include/generated/asm/preempt.h
WRAP arch/arm/include/generated/asm/hash.h
CHK include/generated/uapi/linux/version.h
UPD include/generated/uapi/linux/version.h
CHK include/generated/utsrelease.h
UPD include/generated/utsrelease.h
Generating include/generated/mach-types.h
CC kernel/bounds.s
GEN include/generated/bounds.h
CC arch/arm/kernel/asm-offsets.s
GEN include/generated/asm-offsets.h
CALL scripts/checksyscalls.sh
HOSTCC scripts/dtc/checks.o
HOSTCC scripts/dtc/data.o
SHIPPED scripts/dtc/dtc-lexer.lex.c
SHIPPED scripts/dtc/dtc-parser.tab.h
HOSTCC scripts/dtc/dtc-lexer.lex.o
SHIPPED scripts/dtc/dtc-parser.tab.c
HOSTCC scripts/dtc/dtc-parser.tab.o
HOSTCC scripts/dtc/dtc.o
HOSTCC scripts/dtc/flattree.o
HOSTCC scripts/dtc/fstree.o
HOSTCC scripts/dtc/livetree.o
HOSTCC scripts/dtc/srcpos.o
HOSTCC scripts/dtc/treesource.o
HOSTCC scripts/dtc/util.o
HOSTLD scripts/dtc/dtc
HOSTCC scripts/genksyms/genksyms.o
SHIPPED scripts/genksyms/lex.lex.c
SHIPPED scripts/genksyms/keywords.hash.c
SHIPPED scripts/genksyms/parse.tab.h
HOSTCC scripts/genksyms/lex.lex.o
SHIPPED scripts/genksyms/parse.tab.c
HOSTCC scripts/genksyms/parse.tab.o
HOSTLD scripts/genksyms/genksyms
CC scripts/mod/empty.o
HOSTCC scripts/mod/mk_elfconfig
MKELF scripts/mod/elfconfig.h
CC scripts/mod/devicetable-offsets.s
GEN scripts/mod/devicetable-offsets.h
HOSTCC scripts/mod/file2alias.o
HOSTCC scripts/mod/modpost.o
HOSTCC scripts/mod/sumversion.o
HOSTLD scripts/mod/modpost
HOSTCC scripts/kallsyms
HOSTCC scripts/pnmtologo
HOSTCC scripts/conmakehash
HOSTCC scripts/bin2c
HOSTCC scripts/sortextable
In file included from scripts/sortextable.c:190:0:
scripts/sortextable.c: In function ‘main’:
scripts/sortextable.h:176:3: warning: ‘relocs_size’ may be used uninitialized in this function [-Wmaybe-uninitialized]
memset(relocs, 0, relocs_size);
scripts/sortextable.h:106:6: note: ‘relocs_size’ was declared here
int relocs_size;
In file included from scripts/sortextable.c:188:0:
int relocs_size;
CC init/main.o
CHK include/generated/compile.h
UPD include/generated/compile.h
CC init/version.o
CC init/do_mounts.o
CC init/do_mounts_rd.o
CC init/do_mounts_initrd.o
LD init/mounts.o
CC init/initramfs.o
CC init/calibrate.o
CC init/init_task.o
LD init/built-in.o
HOSTCC usr/gen_init_cpio
/home/atmark/linux-3.14.38-at2/usr/Makefile:73: recipe for target 'usr/initramfs_data.cpio.gz' failed
make[1]: *** [usr/initramfs_data.cpio.gz] Error 1
Makefile:843: recipe for target 'usr' failed
make: *** [usr] Error 2
どうしたらいいのかな。教えて頂けないでしょうか。宜しくお願いします。
