カーネルをビルと手順に従ってビルトすると失敗します。
k.nishijo
2019年6月13日 13時00分
西條と申します。
10.2. Linuxカーネルをビルドする
に従ってlinux-v4.14-at12 をビルとしようとすると下記エラーが発生します。
やり方をご教示ください。
以下、実行結果です。
atmark@atde7:~/kernel/linux-v4.14-at12$ make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- LOADADDR=0x82000000 uImage
scripts/kconfig/conf --silentoldconfig Kconfig
SYSHDR arch/arm/include/generated/uapi/asm/unistd-common.h
SYSHDR arch/arm/include/generated/uapi/asm/unistd-oabi.h
SYSHDR arch/arm/include/generated/uapi/asm/unistd-eabi.h
CHK include/config/kernel.release
UPD include/config/kernel.release
WRAP arch/arm/include/generated/uapi/asm/bitsperlong.h
WRAP arch/arm/include/generated/uapi/asm/errno.h
WRAP arch/arm/include/generated/uapi/asm/ioctl.h
WRAP arch/arm/include/generated/uapi/asm/ipcbuf.h
WRAP arch/arm/include/generated/uapi/asm/msgbuf.h
WRAP arch/arm/include/generated/uapi/asm/param.h
WRAP arch/arm/include/generated/uapi/asm/poll.h
WRAP arch/arm/include/generated/uapi/asm/resource.h
WRAP arch/arm/include/generated/uapi/asm/sembuf.h
WRAP arch/arm/include/generated/uapi/asm/shmbuf.h
WRAP arch/arm/include/generated/uapi/asm/siginfo.h
WRAP arch/arm/include/generated/uapi/asm/socket.h
WRAP arch/arm/include/generated/uapi/asm/sockios.h
WRAP arch/arm/include/generated/uapi/asm/termbits.h
WRAP arch/arm/include/generated/uapi/asm/termios.h
WRAP arch/arm/include/generated/asm/clkdev.h
WRAP arch/arm/include/generated/asm/current.h
WRAP arch/arm/include/generated/asm/early_ioremap.h
WRAP arch/arm/include/generated/asm/emergency-restart.h
WRAP arch/arm/include/generated/asm/exec.h
WRAP arch/arm/include/generated/asm/extable.h
WRAP arch/arm/include/generated/asm/irq_regs.h
WRAP arch/arm/include/generated/asm/kdebug.h
WRAP arch/arm/include/generated/asm/local.h
WRAP arch/arm/include/generated/asm/local64.h
WRAP arch/arm/include/generated/asm/mm-arch-hooks.h
WRAP arch/arm/include/generated/asm/msi.h
WRAP arch/arm/include/generated/asm/parport.h
WRAP arch/arm/include/generated/asm/preempt.h
WRAP arch/arm/include/generated/asm/rwsem.h
WRAP arch/arm/include/generated/asm/seccomp.h
WRAP arch/arm/include/generated/asm/segment.h
WRAP arch/arm/include/generated/asm/serial.h
WRAP arch/arm/include/generated/asm/simd.h
WRAP arch/arm/include/generated/asm/sizes.h
WRAP arch/arm/include/generated/asm/timex.h
WRAP arch/arm/include/generated/asm/trace_clock.h
CHK include/generated/uapi/linux/version.h
UPD include/generated/uapi/linux/version.h
CHK include/generated/utsrelease.h
UPD include/generated/utsrelease.h
HOSTCC scripts/basic/bin2c
SYSNR arch/arm/include/generated/asm/unistd-nr.h
GEN arch/arm/include/generated/asm/mach-types.h
SYSTBL arch/arm/include/generated/calls-oabi.S
SYSTBL arch/arm/include/generated/calls-eabi.S
CC kernel/bounds.s
CHK include/generated/bounds.h
UPD include/generated/bounds.h
CHK include/generated/timeconst.h
UPD include/generated/timeconst.h
CC arch/arm/kernel/asm-offsets.s
CHK include/generated/asm-offsets.h
UPD include/generated/asm-offsets.h
CALL scripts/checksyscalls.sh
HOSTCC scripts/dtc/dtc.o
HOSTCC scripts/dtc/flattree.o
HOSTCC scripts/dtc/fstree.o
HOSTCC scripts/dtc/data.o
HOSTCC scripts/dtc/livetree.o
HOSTCC scripts/dtc/treesource.o
HOSTCC scripts/dtc/srcpos.o
HOSTCC scripts/dtc/checks.o
HOSTCC scripts/dtc/util.o
SHIPPED scripts/dtc/dtc-lexer.lex.c
SHIPPED scripts/dtc/dtc-parser.tab.h
HOSTCC scripts/dtc/dtc-lexer.lex.o
SHIPPED scripts/dtc/dtc-parser.tab.c
HOSTCC scripts/dtc/dtc-parser.tab.o
HOSTLD scripts/dtc/dtc
CC scripts/mod/empty.o
HOSTCC scripts/mod/mk_elfconfig
MKELF scripts/mod/elfconfig.h
HOSTCC scripts/mod/modpost.o
CC scripts/mod/devicetable-offsets.s
CHK scripts/mod/devicetable-offsets.h
UPD scripts/mod/devicetable-offsets.h
HOSTCC scripts/mod/file2alias.o
HOSTCC scripts/mod/sumversion.o
HOSTLD scripts/mod/modpost
HOSTCC scripts/kallsyms
HOSTCC scripts/pnmtologo
HOSTCC scripts/conmakehash
HOSTCC scripts/sortextable
CC init/main.o
CHK include/generated/compile.h
UPD include/generated/compile.h
CC init/version.o
CC init/do_mounts.o
CC init/do_mounts_initrd.o
AR init/mounts.o
CC init/initramfs.o
CC init/calibrate.o
CC init/init_task.o
AR init/built-in.o
HOSTCC usr/gen_init_cpio
./scripts/gen_initramfs_list.sh: Cannot open 'initramfs_a600.cpio.gz'
usr/Makefile:57: ターゲット 'usr/initramfs_data.cpio.gz' のレシピで失敗しました
make[1]: *** [usr/initramfs_data.cpio.gz] エラー 1
Makefile:1039: ターゲット 'usr' のレシピで失敗しました
make: *** [usr] エラー 2
最新のほうを参考にやってみましたが、今度は以下のエラーが発生してしまいます。
<途中略>
AR sound/x86/built-in.o
CC sound/last.o
AR sound/built-in.o
MK_FW firmware/imx/sdma/sdma-imx6q.bin.gen.S
make[1]: *** 'firmware/imx/sdma/sdma-imx6q.bin.gen.o' に必要なターゲット '/lib/firmware/imx/sdma/sdma-imx6q.bin' を make するルールがありません. 中止.
Makefile:1039: ターゲット 'firmware' のレシピで失敗しました
make: *** [firmware] エラー 2
以上よろしくお願いします。
> 佐藤です。
> 参照していただいてるマニュアルの版が古いようです。
> 以下が最新ですのでこちらを参照くだざい。
