takeiwata
2019年12月30日 13時41分
STATE→connecting (prepare)からconnectedになりません。
mmcli -m 0とsyslog一部抜粋した内容になります。
SIMはDOCCOMO 閉域網です。
お正月明けに現場に設置予定ですが、相談する人がいなく困っております。
EVICE TYPE STATE CONNECTION
eth0 ethern、et connected Wired connection 1
★ttyACM0 gsm connecting (prepare) gsm-ttyACM0
usb0 ethernet unavailable --
gre0 gre unmanaged --
gretap0 gretap unmanaged --
ip6gre0 ip6gre unmanaged --
ip6tnl0 ip6tnl unmanaged --
tunl0 ipip unmanaged --
lo loopback unmanaged --
sit0 sit unmanaged --
ip6_vti0 vti6 unmanaged --
①mmcli -m 0
Hardware | manufacturer: 'Cinterion'
| model: 'ELS31-J'
| revision: 'REVISION 4.3.2.1b'
| supported: 'gsm-umts'
| current: 'gsm-umts'
| equipment id: '356778070241246'
System | device: '/sys/devices/soc/30800000.aips-bus/30b20000.usb/ci_hdrc.1/usb2/2-1'
| drivers: 'cdc_acm, cdc_ether'
| plugin: 'Cinterion ELS'
| primary port: 'ttyACM0'
| ports: 'ttyACM0 (at), usb1 (net)'
Numbers | own : '***********'
Status | lock: 'none'
| unlock retries: 'unknown'
| state: 'registered'
| power state: 'on'
| access tech: 'lte'
| signal quality: '93' (recent)
Modes | supported: 'allowed: 2g; preferred: none'
| current: 'allowed: 2g; preferred: none'
Bands | supported: 'unknown'
| current: 'unknown'
IP | supported: 'none'
3GPP | imei: '***********'
| enabled locks: 'none'
| operator id: 'unknown'
| operator name: 'unknown'
| subscription: 'unknown'
| registration: 'home'
SIM | path: '/org/freedesktop/ModemManager1/SIM/0'
Bearers | paths: '/org/freedesktop/ModemManager1/Bearer/0'
②syslog内容 Retryingしている?
Dec 30 13:32:02 armadillo ModemManager[6373]: Retrying status check in aa
second. 63 retries left.
Dec 30 13:32:02 armadillo ModemManager[6373]: (ttyACM0) device open counn
t is 1 (close)
Dec 30 13:32:03 armadillo ModemManager[6373]: (ttyACM0) device open counn
t is 2 (open)
Dec 30 13:32:03 armadillo ModemManager[6373]: (ttyACM0): --> 'AT+CGPADDRR
Dec 30 13:32:03 armadillo ModemManager[6373]: (ttyACM0): <-- '+CC
GPADDR: 1OK'
Dec 30 13:32:03 armadillo ModemManager[6373]: Retrying status check in aa
second. 62 retries left.
t is 1 (close)
Dec 30 13:32:04 armadillo ModemManager[6373]: (ttyACM0) device open counn
t is 2 (open)
Dec 30 13:32:04 armadillo ModemManager[6373]: (ttyACM0): --> 'AT+CGPADDRR
Dec 30 13:32:04 armadillo ModemManager[6373]: (ttyACM0): <-- '+CC
GPADDR: 1'
Dec 30 13:32:04 armadillo ModemManager[6373]: (ttyACM0): <-- 'OKK
Dec 30 13:32:04 armadillo ModemManager[6373]: Retrying status check in aa
second. 61 retries left.
t is 1 (close)
Dec 30 13:30:01 armadillo ModemManager[6373]: (ttyACM0): <-- 'OKK
Dec 30 13:30:01 armadillo ModemManager[6373]: Retrying status check in aa
second. 20 retries left.
Dec 30 13:30:01 armadillo ModemManager[6373]: (ttyACM0) device open counn
t is 1 (close)
Dec 30 13:30:02 armadillo ModemManager[6373]: (ttyACM0) device open counn
t is 2 (open)
Dec 30 13:30:02 armadillo ModemManager[6373]: (ttyACM0): --> 'AT+CGPADDRR
Dec 30 13:30:02 armadillo ModemManager[6373]: (ttyACM0): <-- '+CC
GPADDR: 1'
Dec 30 13:30:02 armadillo ModemManager[6373]: (ttyACM0): <-- 'OKK
Dec 30 13:30:02 armadillo ModemManager[6373]: Retrying status check in aa
second. 19 retries left.
t is 1 (close)
Dec 30 13:30:03 armadillo ModemManager[6373]: (ttyACM0) device open counn
t is 2 (open)
Dec 30 13:30:03 armadillo ModemManager[6373]: (ttyACM0): --> 'AT+CGPADDRR
Dec 30 13:30:03 armadillo ModemManager[6373]: (ttyACM0): <-- '+CC
GPADDR: 1'
Dec 30 13:30:03 armadillo ModemManager[6373]: (ttyACM0): <-- 'OKK
Dec 30 13:30:03 armadillo ModemManager[6373]: Retrying status check in aa
second. 18 retries left.
t is 1 (close)
Dec 30 13:32:05 armadillo ModemManager[6373]: (ttyACM0) device open counn
t is 2 (open)
Dec 30 13:32:05 armadillo ModemManager[6373]: (ttyACM0): --> 'AT+CGPADDRR
Dec 30 13:32:05 armadillo ModemManager[6373]: (ttyACM0): <-- '+CC
GPADDR: 1'
Dec 30 13:32:05 armadillo ModemManager[6373]: (ttyACM0): <-- 'OKK
Dec 30 13:32:05 armadillo ModemManager[6373]: Retrying status check in aa
second. 60 retries left.
t is 1 (close)
Dec 30 13:32:06 armadillo ModemManager[6373]: (ttyACM0) device open counn
t is 2 (open)
Dec 30 13:32:06 armadillo ModemManager[6373]: (ttyACM0): --> 'AT+CGPADDRR
Dec 30 13:32:06 armadillo ModemManager[6373]: (ttyACM0): <-- '+CC
GPADDR: 1OK'
Dec 30 13:32:06 armadillo ModemManager[6373]: Retrying status check in aa
second. 59 retries left.
t is 1 (close)
takeiwata
> 古関です。
> ログを確認しました。
> ドコモの基地局には登録できています。
> データ通信を開始できずにタイムアウトしている状況です。
> > SIMはDOCCOMO 閉域網です。
> もし差し支えなければもう少し詳しくSIMの情報をいただけますか?
> ※ 認証方式(PAP/CHAP)や具体的な契約内容など
> よろしくお願いいたします。
早速のご回答ありがとうございます。
先ほど、connectedできました。
ユーザーIDにミスがあり、修正したら接続できました。
root@armadillo:~# nmcli device
DEVICE TYPE STATE CONNECTION
eth0 ethernet connected Wired connection 1
ttyACM0 gsm connected gsm-ttyACM0
これからdnatを設定する必要があります。
構成
LTE(閉域網 IP:*.*.*.*)-G3L(IP:192.168.10.1)-PLC(IP:192.168.10.2 ポート9094)
下記のようなdnat設定は可能でしょうか?
LTE IP:*.*.*.* ポート 5001→PLC(IP:192.168.10.2 ポート 9094) PLC本体
LTE IP:*.*.*.* ポート 80 →PLC(IP:192.168.10.2 ポート 80) webサーバー
LTE IP:*.*.*.* ポート 21 →PLC(IP:192.168.10.2 ポート 21) FTP
at_koseki
古関です。
> 早速のご回答ありがとうございます。
> 先ほど、connectedできました。
接続できたようで良かったです。
> 構成
> LTE(閉域網 IP:*.*.*.*)-G3L(IP:192.168.10.1)-PLC(IP:192.168.10.2ポート9094)
> LTE IP:*.*.*.* ポート 5001→PLC(IP:192.168.10.2 ポート9094) PLC本体
> LTE IP:*.*.*.* ポート 80 →PLC(IP:192.168.10.2 ポート80) webサーバー
手元に機材がなく動作確認ができないのですが、技術的には可能と思います。
ただ、2つ注意点があります。
〇 LTEでデータ通信をする場合のネットワーク構成について
下記製品マニュアルをご確認ください。
おそらく次のようなネットワーク構成にする必要があると思います。
閉域網-- G3L LTEモジュール内部(IP:*.*.*.* - IP:192.168.15.*)- G3L Host(IP:192.168.15.* - IP:192.168.10.1) -- PLC(IP:192.168.10.2ポート9094)
〇 G3L搭載LTEモジュール内部で動作するファイヤーウォールについて
閉域網側からG3LにSSHなどでログインをする場合、
初期出荷状態では、G3L搭載LTEモジュール内部で動作しているファイヤーウォールによってログインできない状況となります。
もし、閉域網側からのアクセスが必要な場合、
製品マニュアル次の章を確認し、このファイヤーウォールを無効化してください。
詳しくは下記製品マニュアルを参照してください。
takeiwata
> 古関です。
> > 早速のご回答ありがとうございます。
> > 先ほど、connectedできました。
> 接続できたようで良かったです。
> > 構成
> ただ、2つ注意点があります。
> 下記製品マニュアルをご確認ください。
マニュアルを読んでもわかりませんでした。
添付ファイルのような構成にしたいです。
Wired connection 1の内容にdnatの情報を追加していくのでしょうか?
ポートNo.指定方法は?
現在の状況
nmcli device
/etc/NetworkManager/system-connections# ls -l
-rw------- 1 root root 276 Dec 31 21:20 Wired connection 1
-rw------- 1 root root 230 Dec 31 20:21 ethernet-eth0
-rw------- 1 root root 235 Dec 30 15:05 gsm-ttyACM0
[ethernet]
mac-address=00:11:0C:20:0C:99
[connection]
id=Wired connection 1
uuid=68ddfd36-554d-48fa-b3b5-030f1c907b66
type=ethernet
timestamp=1577790942
[ipv6]
method=auto
[ipv4]
method=manual
address1=192.168.1.10/24
never-default=true
コネクシオG3L設定.pdf |
at_koseki
2019年12月30日 13時52分
古関です。
ログを確認しました。
ドコモの基地局には登録できています。
> SIMはDOCCOMO 閉域網です。
